Anyone ever re-arch their own leaf springs? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2005, 11:18 AM
Just wondering, has anyone ever tried re-arching their leaf springs? I don't mean to lower them, I need to raise them. Mine are sagging badly and frankly don't have $300 or so to replace them right now. Shackls look awfull to me.
These are on a German 72 Ford Capri. I called a local place but they said they would need to know the original specs before they could do anything with them.
I was thinking about suspending the enitre body with jack stands and let the axle hang. Then use another set of stands adjusted just under the rear axles. Then heat each side with a torch until the weight of the axle sags the spring down to the level of the jack stand. Just the opposite of what would be done to lower a car by heating the springs.
Anyone ever try it? These are three leaf. Would I have to get it red hot? How far of a drop would equate to a rise in ride height? Should I cool them with oil or water to temper them? I imagine I would have to slip the extra leafs out and heat/bend them separate from the main leaf.
Old 06-28-2005, 01:55 PM
abstruse dutch uncle
I think rapid heating and cooling would make them brittle, and it for sure wouldn't last long. They'll be sagging again the first time you load them.
I think you would have to cool them very slowly, in an oven, or in a hot sand box. Or cold bend them somehow maybe.... that might not last either.
Rapid red-heating/cooling makes them hard, but brittle, then heating again to a near red state and very slow cooling would give them ....elasticity (is there a better word?)
Why not just get some leaf spring helpers?
There's at least 3 different kinds. I like the ones that go on top.... either an extra leaf assembly on top, or a bowstring coil. The ones that go on the bottom will just eventually make a bad leaf worse.
Or you can add a couple leaves from an s10 or something maybe?
Last set of brand new leafs I bought were $120 for the pair with front eye bushing. Then add any bolts, shackles and cushions needed.
Old 06-29-2005, 12:50 AM
Whatever you do don't heat up the leaves!!!!!
Take the leaves into that local shop and tell them you want however much more lift from what it has now. If you want 1" more tell them you want them to re-arch them with 1" more free arch. Also tell them that you won't gripe when they arn't the height you want them and will pay to have it done again when it doesn't turn out right.
It will cost less to do it this way then it would to screw up the leaves (what you would do by heating them) and have to buy a new set anyways.
Old 07-12-2005, 08:57 PM
let 'er go!
leaf arcing
Dude, if you take your leaf pack apart, and they are still in good condition, bring them to a muffler shop. I work in a MMufler shop and I have re-arced leafs using our pipe bender! CRUDE, but effective. Dont heat. gl
Rear Leaf Springs ...."Clamping Them?" white66coupe Suspension - Brakes - Steering 12 03-11-2006 01:04 PM
Not Parallel Leaf Springs evltwin Suspension - Brakes - Steering 3 01-04-2005 09:27 PM
leaf springs and coil overs jhenry Suspension - Brakes - Steering 2 11-25-2004 06:45 AM
leaf springs for 68 firebird 67bird Suspension - Brakes - Steering 4 10-19-2004 05:57 AM
need some cross referencing of leaf springs TooMany2count Suspension - Brakes - Steering 1 10-02-2003 08:21 PM
