Anyone ever replace '87 Camaro door hinges - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2008, 05:48 AM
I have a Camaro with saggy hinges on the driver side and the top one is welded to the door. Are the pins on the top hinge replaceable or would the whole hinge be cut from the door?
Old 03-29-2008, 08:38 AM
chevelle_man64's Avatar
I am the Chevelle Man!
Last journal entry: Grill Support
Is it welded to the car and the door both?
Old 03-29-2008, 11:56 AM
It's welded to the door but bolted to the car. I asked a parts house and they didn't know if there was a pin kit for the top or not.
Old 03-29-2008, 06:10 PM
DRS50's Avatar
Last journal entry: Epoxy primed the body today
try this, but get a good grip on your chair because they aint cheap.
www.paddockparts.com
door hinge repair kit C57D repairs 1 side
door hinge pin X14560
Door hinge repair kits
FPK1
FPK2
FBK3
FBK4
GM upper door hinge RH/LH # 12392848
GM lower door hinge RH #12510463 LH #12392847 on door
GM lower door hinge RH # 20314680 LH #20314681 on body
Old 03-29-2008, 10:10 PM
Rag top bird's Avatar
Hot rods are still the king
Here are some phots that may help you good luck http://www.chevyhiperformance.com/te...aro/index.html
Old 03-29-2008, 10:50 PM
Here's another tip on the subject..Tip of the day here at Hotrodders..... click here.
Old 03-30-2008, 12:51 AM
Thanks guys I looked on Ebay and the have the upper hinge pins there so now at least I can start to pull everything apart.
Can I make my 78 firebird into a Camaro? Suckingas Body - Exterior 9 06-28-2010 11:06 PM
68 Camaro Headers and Power Steering BuddyK Engine 3 12-01-2006 09:17 PM
72 camaro nose on a 78 camaro roy383ci Body - Exterior 3 02-25-2006 05:59 PM
87 Camaro 87 camaro Introduce Yourself 2 02-21-2006 11:30 PM
87 camaro 700r4 woes & ?'s... tspalletta Transmission - Rearend 2 07-15-2005 06:40 PM
