Anyone ever use extra fine grade steel wool for scuffing primer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2012, 12:02 PM
rusthater89's Avatar
I wanna scuff up some epoxy i have on a trunk so I can do my 2k primer. Anyone ever use extra fine grade steel wool.
I don't have any scotch brite pads but I have a bunch of this steel wool.
Old 05-26-2012, 06:57 PM
deadbodyman's Avatar
Wiki Edits: 11
absolutely ,positively never ,ever use steel wool anywhere near a car.what happens is little pieces break of all over everything getting everywhere and the slightest bit of moisture starts them rusting by the time you notice the little rust specks ,its too late...we thought they worked fantastic for cleaning up chrome until one day .....now old paint is a little different you can clean the chrome up but you better blow the whole car off real well and even then you wont know if you got them all until it rains out and its to late its just not worth it get scuff pads they're only about 5.00 for three ,enough to do three cars they also dont sand they scuff and are worthless to sand primer with you need sand paper ,scuff the primer AFTER you sand..
there's a bronze wool that's made just for using on or around cars
Old 05-26-2012, 07:16 PM
I'm a little confused. Your saying that the steel wool breaks off and gets trapped in spaces. It then begins to rust.
What does that have to do with the panel that is coated in primer?
Old 05-26-2012, 08:48 PM
Wiki Edits: 11
Is the panel on the car? doing it off the car wouldnt be as bad ... the steel powder sticks and rusts to primer just as nice as it does on paint all you need is one humid day to get it going
Old 05-26-2012, 08:56 PM
Damn, I didn't realize that would happen guess I'll get some scuff pads.
thanks.
Old 05-27-2012, 12:25 AM
Wiki Edits: 11
My new shower stall is cured,gel coated fiberglass,it was ruined in one week from me grinding metal. the metal dust sticks to the fiberglass then starts rusting, eating right in,I haven't found anything yet that will get rid of it...rust specks everywhere.
Grade 8 bolt with grade 8 washers STUDE55DOG Engine 11 07-11-2011 06:21 PM
Epoxy Primer Brands with a passing Grade ? outoftouch Body - Exterior 11 03-06-2010 11:20 AM
Grit - how fine is too fine for adhesion? cboy Body - Exterior 41 06-28-2009 04:20 PM
Scuffing well cured epoxy primer. jcarter Body - Exterior 11 11-18-2007 02:33 PM
What grade of steel for... 1tunda Suspension - Brakes - Steering 2 08-02-2006 12:28 AM
