anyone got a jeep with a 4.0L in it? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2009, 04:11 PM
fast68's Avatar
likes chevy trucks & boobies
i need to find someone who has a jeep smething like a cherokee with a 4.0 in it around 86-92 years or so i need to see about three 12 or so guage wires on pass side near distributor harness where they go
one is striped
two others are solid without any striping
all three same guage wire
also if i could see crank sensor wire harness plug at top side of engine by fuel injector rail that would be awesom too
so i can see which color wires g to which between the connectors
red and white smaller wires
and white with black stripe and purple wires a little larger guage than the red and white ones going down to the sensor in the bellhousing
pics or tell me which wires go to which and where the three green wires go ??
what they are for on these ?
thanks!!
Old 08-14-2009, 04:49 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I have a 94 G Cherokee Ltd. w/4.0L. Don't know if this will help or not.
This is all on the pass. side of the eng.
There are 3 ring terminals in the left photo that are all grounds. 1 has 1 wire, the other 2 have 2 wires each.
To the right of the grounds is the oil pressure sender w/2 wires and a weatherpac connector.
The right photo shows the 3 wire WP connector that is also on the pass. side, behind the grounds, towards the back of the engine. I believe it goes to the crank pos. sensor.
Name:	jeep wiring 002.jpg
ID:	39982   Click image for larger version
Name:	jeep wiring 003.jpg
distributor indexing jeep 4.0L fast68 Engine 4 08-18-2009 12:25 PM
97 jeep 4.0L idle woes. Scrumgees Engine 3 08-13-2009 03:04 PM
jeep shifter on a toplaoder? ajbcc2 Hotrodding Basics 7 10-10-2008 01:04 AM
Willys?? scott011422 Hotrodders' Lounge 28 08-21-2007 12:57 PM
Jeep OBDII Code? TonyMac Engine 2 06-09-2004 08:24 PM
