Anyone had experience with Unistear rack and pinion kits for 28-32 fords? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2012, 08:01 PM
They offer two types of kit. One is designed to replace the vega cross steering set ups, and the other is designed to be center mounted under the spring perch. I'm considering the later.
I'd appreciate any feedback on either version.
Old 08-23-2012, 09:50 PM
I have the one in my 32 3W that replaces the VEGA
I like it. I have almost 9 thousand miles on it and it drives good. I have a VEGA box in my 32 roadster and they drive differently. Both drive OK but just have a different road feel.
The Following User Says Thank You to Deuce For This Useful Post:
1ducatiboy (08-25-2012)
Old 08-24-2012, 10:41 AM
boatbob2
Rubber boot......
Hi,i have a fatman irs in my 48 ford coupe,the rubber boots on the irs have been replaced 3 times,in the past 4 years,AND i havent even finished the car to drive it,the boots,NAPA are junk,(chinese) where can i get GOOD boots??
Old 08-25-2012, 09:50 AM
454 Rattler's Avatar
NEVER SATISFIED !!
I used the same one as Deuce. I replaced a Vega unit after using it for hundreds of miles. They do drive differently but the Unisteer was much nicer.
454 RATTLER
Mustang II rack and pinion, pinion Jim H Suspension - Brakes - Steering 3 02-23-2012 12:58 PM
s 10 rack and pinion 64chevyii Suspension - Brakes - Steering 3 01-24-2012 07:54 PM
rack and pinion filbee Suspension - Brakes - Steering 6 06-26-2005 11:17 PM
Rack and pinion????? sack Suspension - Brakes - Steering 1 03-31-2004 07:20 AM
Rack and pinion CustomFord Suspension - Brakes - Steering 2 01-29-2003 06:30 PM
