Anyone have 54-56 Ford Front Frame Pictures? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2007, 02:37 PM
60tbirdrick's Avatar
Sacred Steel
Last journal entry: The dash
Hey fellas,
I'm looking for 54-56 Ford front end pictures where the steering linkage is if anyone has them. I am interested in the mounting locations for the steering box and idler arm bracket. I also need the distance between the frame where these two components bolt up and the length of the center link. I am trying to see if I can make Fatmans Rack & Pinion kit for the 54-56 Ford work on my T-bird with maybe a little modification. I have some other ideas also but i'm trying to look at all possible options before I decide what I am going to do. One good thing is that I have another 60 Tbird up on a rotisserie so I can mock up my steering system on that before I put it on my other one. Any help would be appreciated. Thanks
Old 02-05-2007, 05:28 AM
brian0605's Avatar
mostly confused
Last journal entry:
I have the service manual. I'm not sure if the dimensions are in it but I'll look. If they are I'll try to scan and post for you. I will hopefully be beginning to work on a 54 ford 2dr sedan. This one will be for me. The one I have pictures of posted is my father in laws. I have spent 12yrs building this one. I'm not going to build mine as "pretty". I think I want to go with the rock a billy rat rod look. Clean, minor customization, flat black, tail dragger. Dog dish hub caps and trim rings. Well anyway I'll let you know. Brian
Old 02-05-2007, 05:31 AM
Sacred Steel
Thanks Brian, that would help a lot.
Old 02-06-2007, 07:12 AM
brian0605's Avatar
mostly confused
Last journal entry:
sorry I haven't done this sooner but, should be posting the info in a few minutes. Brian
Old 02-06-2007, 07:29 AM
brian0605's Avatar
mostly confused
Last journal entry:
[IMG][/IMG]
Gonna send this and see how it looks, I may have to magnify it.These are the frame deminsions for a 54 ford as you will note the frames for the coupe sedan and convertible look to be all the same. Hope this helps.Brian
Old 02-06-2007, 07:47 AM
brian0605's Avatar
mostly confused
Last journal entry:
I think it is legible. let me know if you have any trouble reading it.Brian
Old 02-06-2007, 05:39 PM
Sacred Steel
Brian, Thanks a lot. I think this is exactly what I need.
Rick
Old 02-06-2007, 06:16 PM
brian0605's Avatar
mostly confused
Last journal entry:
Well I hope it helps. It is from the 52-54 ford service manual. That frame is from the 54 section. Good luck let me know how it turns out. Post some pictures if you can. Only a few more weeks til I get my new project. Brian
36 Ford Pickup on a Ford Ranger Frame? Fasteddy General Rodding Tech 21 12-08-2012 11:25 AM
Fiberglass Front Clip for 51 Ford P/U sandidande Body - Exterior 10 05-17-2007 07:25 AM
29 Ford...Box the frame? RodGuyinCO Hotrodding Basics 5 12-14-2006 07:38 AM
32 ford front suspension droddy Suspension - Brakes - Steering 3 12-03-2006 06:30 PM
36 Ford frame repair... CamSweet Suspension - Brakes - Steering 5 07-10-2006 04:20 PM
