Anyone have camel hump measurements in their bag of tricks - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2012, 07:18 AM
hcompton's Avatar
Old & Furious
Anyone have camel hump dimensions in their bag of tricks. I am building an intake and need to get some dimensions for the fuelie style double hump heads. These heads were used as a starting point to design most after market heads. So I am going to fit my new intake system to these heads. Helps that my build up block has a rusty set of these still in place from the 60's (No holes Drilled)
I was hoping someone would have the dimensions maybe an exploded view with measurements. I figured someone out there must have this info close at hand. A quick google search did not turn up any thing other than port cc which is not going to help much. I will need to take measurements at some point but not wanting to spend hours going back and forth getting on size at a time. and gaskets can only tell me so much. Also was interested in knowing the size and shape of the water jackets. But that is for another project.
I will be redesigning for vortec/18 degree/ big cheif as time goes on. But for now just starting with the 23 degree stuff. I will make my way to LS at some point.
Not going into the design at this stage. but I will post some picks once its built and i have dyno results. Since i may build ten of them before i am happy no need to waste your time. Thanks in advance for any help you can provide.
Camel Hump Head ID 31fordcoupe Engine 6 03-28-2012 01:27 AM
Help with camel hump heads speedball Hotrodding Basics 12 09-27-2011 03:41 PM
camel hump heads i1964ss Engine 4 10-03-2009 09:47 PM
camel hump heads yakimaracer01 Engine 1 07-06-2009 03:15 PM
camel hump or double hump cheezbay Engine 3 03-25-2004 11:22 AM
