-   -   Anyone have a guide on how to gap spark plugs on custom engine? (http://www.hotrodders.com/forum/anyone-have-guide-how-gap-spark-plugs-custom-engine-122482.html)
timothy9972 08-18-2007 08:38 PM
Chevy 350 .040 over/ "double hump" 2.02 heads (been shaved with 59 cc chambers now), forged flat top pistons, compression ratio 11.72:1, XE274H cam (Lift .487/ .490), HEI, Edlebrock 650 CFM carb
any other info I need to provide?
Thanks
ps using accel header plugs
techinspector1 08-18-2007 09:08 PM
Using 0.039" compressed for the gasket, zero deck, 5 cc's in the piston eyebrows I get 11.08:1 static c.r. I don't see how you could get to 11.72 with flat-tops in a 350. Even at 11.08, the cam's too short.
Anyway, with that much compression, start with a gap of 0.035". Widen it a little at a time to experiment, depending on your ignition system and the coil you're using.
Greg T 08-18-2007 10:31 PM
With that much static you have more than plug gap to be concerned with. I would immediately change the cam to the comp 292 to bleed off some of that cranking pressure.
timothy9972 08-18-2007 11:14 PM
metal shim gasket with a compressed thickness of .015, and the block has been milled
techinspector1 08-19-2007 12:41 AM
So, what does the squish measure?
timothy9972 08-19-2007 07:47 AM
What is squish?
Greg T 08-19-2007 08:04 AM
The squish or quench area is the gap between the piston flat and the head flat @ TDC, which allows the flame to accelerate and cool during ignition. The wider the quench area the more resistance you have to detonation. Also, the quench is a safety net so that your piston doesnt make contact with the head. You cant just deck blocks, shave heads and throw in some domed slugs. Life is not that easy.
techinspector1 08-19-2007 01:15 PM
Well, actually, the narrower the squish is, the more resistant the motor is to detonation. But there is a mechanical limit to how narrow you can go. That's why I was saying I don't see how you can build a 11.72 motor with 59 cc heads and flat-top pistons.
Timothy, how far down in the bore is the piston at top dead center?
timothy9972 08-19-2007 02:04 PM
.010 in the hole at TDC
we did check the valve to piston clearance with some clay and there is plenty of clearance
techinspector1 08-19-2007 03:31 PM
With the piston 0.010" in the hole and a 0.015" gasket, the piston to head clearance is only 0.025". GOOD LUCK.
timothy9972 08-19-2007 07:32 PM
The heads are already bolted down and I sat the engine in the car yesterday. This is my first real build. Watched and helped many times but this is my first time to do it and even then I had a friend that is familiar with Mopars help out. SO it is all new to me.
Greg T 08-19-2007 10:05 PM
Of course it is and I've known this for years. But when I type in a hurry I get brain farts!! ;)
Jmark 08-19-2007 10:33 PM
So that's what I smelled when I sat down here? :nono:
jimfulco 08-20-2007 08:47 PM
.025" might work on a Mopar, but on a Chevy, you're just begging the pistons to hit the heads.
GM makes .026" shim gaskets for less than $10 each, and .028" composition gaskets for a little more. I'd be more comfortable with one of those.
