Anyone have an idea...balance flywheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-12-2005, 08:06 PM
357f-150's Avatar
Its saturday and well out of boredom thought I would ask...
...anyone have a rough idea what it would cost to take a OE flywheel from zero balance to 28oz? I have an I-6 (zero) flywheel needs to go behind a 351w (28oz). Otherwise they are identical.
I will find out monday, just looking for a good guesstimate to give me something to think about until then.
Thanks
Old 02-13-2005, 05:49 AM
stu stu is offline
dollar three ninety five.
Old 02-13-2005, 06:47 AM
357f-150's Avatar
Good guesstimate, not intoxicated thoughts???
Old 02-13-2005, 06:49 AM
stu stu is offline
Too early for intoxification. If I intoxificated that is.
Old 02-13-2005, 07:30 AM
357f-150's Avatar
Too early, is that possible?
Old 02-13-2005, 07:53 AM
Tazz
Its always 5 o'clock some where!!
Isn't that in the song?? Have a great night guys!! Its Sunday morning here.
Tazz
Rat Rods Rule!
Old 02-14-2005, 04:01 PM
357f-150's Avatar
Well guess what tranny shops DON'T do?
Apparently they are considered two seperate things, the tranny tech said," you need a flywheel shop or machine shop." ah...uh...okay??
Hopefully I will have bettter luck when I get in touch with a local speed shop.
Old 02-14-2005, 04:19 PM
stu stu is offline
Well I could have told you so.
Why not try it yourself?
Obtain a 28oz. flex plate and mark where the weight is in relation to the bolt holes.
Remove the weight from the flex plate.
Make this same mark on the flywheel.
Balance the flywheel in the center.
Drill that portion of the flywheel oposite the weighted area.
Remove enough metal to obtain a balance when the 28oz is placed in the drilled area.
When it balances you are set to go.
Old 02-14-2005, 04:24 PM
357f-150's Avatar
Sounds easy enough but I'd rather pay someone to screw it up, I feel better when I can blame others...j/k.
Something to think about though..thanks
Old 02-14-2005, 06:41 PM
stu stu is offline
Well yeah I guess it is better if you can point finger.
Personally I have an a.s.s. kicking tree in my back yard.
