Well the # I found was 10306, the # 10309 was for valve springs.I guess they miss stamped it,anyways....Hydraulic cam ,2800-6200 rpm,228* @ .050, 284* advertised dur. 112 L/S , .544 lift. Hope this helps
Is this information from an old Dynamics catalog or from a current cranecams catalog? Thanks. Last edited by jim larson; 01-04-2011 at 08:09 AM. |
Cool! I actually found the specs in my 2005 Crane master catalog. I knew that they had bought CD a few years back and that they were single pattern grinds. I just wasn't sure about the #s because of the miss stamping. Good luck with the project
Just checked my static and dynamic and found them to be 9.7 and 7.6. Does that 7.7 seem a little low? Could that be the problem with 92 octane gas, so I have to bump it up with Supreme 130? thanks.
If it only takes 1 quart of race gas in 10 gallons to supress the detonation you should be able to tune it out with some fine tuning.
Make sure no oil is getting in the combustion chambers. PCV/valve covers baffles, intake manifold gasket vacuum leaks. Make sure you have the correct type and heat range spark plugs. Correct carb jetting, no intake leaks. Sufficiant fuel flow volume under power. Correct spark advance (initial mechanicalcurve and limit and vacuum advance.) mechanical should not exceed 38deg BTDC at max advance. vacuum advance is critical and should not exceed +12deg at the most. Recurving the distributor will help the throttle response and detonation threshold. If the real compression ratio is 10.5:1 or less you should be able to get it right with tuning. If the camshaft is/was installed too far advanced the engine will ping more readily. (verify .050" open close timing points) |
Actually, I used that cam in a 468 BBC I built in about '95. It was a good cam, I really liked it.
| Cam Dynamics Catalog | F-BIRD'88 | Engine | 23 | 04-18-2011 08:37 AM |
| Need Cam Dynamics Cam Info | sykora9280 | Introduce Yourself | 1 | 11-04-2010 05:19 PM |
| Need help with cam dynamics cam specs | reimeracing | Engine | 3 | 01-29-2010 01:44 PM |
| Cam Dynamics | rjae540 | Engine | 0 | 07-21-2009 08:54 PM |
| cam dynamics ???? | classic72muscle | Hotrodding Basics | 3 | 04-21-2008 12:27 PM |
