-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   anyone have opinions on these valve spring compressors? (http://www.hotrodders.com/forum/anyone-have-opinions-these-valve-spring-compressors-37802.html)
Dubz 04-15-2004 11:11 AM
found out these same valve spring compressors are going on sale in about a weeks time at a store up here, same brand even.
http://www.hdtools.co.uk/stores/page...phics/js5e.jpg
So does anyone have any opinions on these spring compressors?? I don't want something that is gonna take a powerlifter to operate or be insufficient for certain applications. Should i go with a different style compressors or any input as to what a good choice would be is appreciated.
Thanks
Dubz
302 Z28 04-16-2004 07:28 AM
Personally I do not like that style, imo they are difficult to use. The style I prefer is the one that looks like a big "C" clamp. If the head is still on the engine I prefer the one that goes over the rocker stud and is a lever that compresses the spring while air is used to pressurize the cylinder.
Vince
johnsongrass1 04-16-2004 10:04 AM
Same here. The head on engine tool works really well as long as you can hold it there long enough to get the keepers in. It's a big help if you have a buddy who can do one of those two. One major downfall is if you are using triple springs with loads of 600 pounds over the nose. Then the mechanical advantage the give you isn't enough.
troy-curt 04-17-2004 06:14 AM
I have a air operated "C" clamp type, that I have used for more than 30 years, and two different lever type. They are all I've ever needed.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
MI2600 04-26-2004 11:07 PM
I've used the levers types, but they seem to push the spring off center.
I inherited a compressor from my Dad that has two arms that engage the spring coils and it has a knob on top for tightening it down. He welded a 5/8" nut on the top of the knob so a socket can be used. Works good for me and it leaves both hands free for handling those pesky keepers. I've seen them for sale...can't remember where though.
Dubz 04-28-2004 09:42 PM
Troy
any idea where i could find one of those air ones or who might make them still, as an air operated one would be the cat's meow
troy-curt 04-29-2004 12:21 AM
I got mine from Snap on.
Troy
tresi 05-02-2004 08:37 AM
That one in the picture will do stock spring if you only use it every once in a while. Heavy spring loads or if you do a lot head work you'll want something stronger.
