-   -   anyone heard of this (http://www.hotrodders.com/forum/anyone-heard-224451.html)
chris78 09-27-2012 10:43 PM
i was watching a old pinks or passtime alittle while back can't remember which and saw a guy running a 391sbc.anybody used or seen this before and how is it built.cant find much on the internet about it and what i do is vague.kinda like to be different and might want to build one if the moneys there.cant afford a 396sbc thought this might be cheaper but may have to settle for a 383 since they have became so cheap. also saw a 364 kinda like to learn about them to.its all about the budget though and how good a mood the wifes in.:D:D:D
OneMoreTime 09-27-2012 11:15 PM
Just a bore size over stock is all that is..
Sam
against all odds 09-28-2012 12:00 AM
i know that if you don't have something nice to say you shouldn't say it, but i can't help it.
PINKS = B.S.
Especially pinks "all out." But you can't go "too fast?"
You see, this is part of what's wrong with society.
painted jester 09-28-2012 01:37 AM
Check this out see if it helps :thumbup:
Hye Tech 391 Stroker Dyno Test - Tech - Lowrider Magazine
Custom crank grinds put your cubic inches to odd sizes that most people don't recognize!
Jester
AutoGear 09-28-2012 01:45 PM
PINKS = B.S.
I still remember when Baldy O'Tool that ran those shows tried to ride a hopped up japanese motorcycle (Hayabusa maybe?) and wiped out. Someone else's bike I might add. Nate that was on there actually had some talent as a builder it seems
Back to bore/stroke; If its an oddball number you haven't heard of; its not going to be as cheap as the stuff you HAVE heard of
painted jester 09-28-2012 08:40 PM
You got that right LOL Its very expensive!! There were a lot of 391s in the 60s wgt to cu.in. class racing You could run faster every pass:D!!! Not bracket racing where you can go too fast :nono: and lose the race LOL There was no sand bagging or looking behind you in class racing wht. to cu. in.
Jester:thumbup:
When he flipped that bike it was so funny I ROTFL!! I wonder who shaves his back?
vinniekq2 09-28-2012 10:34 PM
392 = 4.155 borex3.62 stroke. basically a 400 block 30 over and the stroke of a new 5.7.
or 4.010 boreX3.875 stroke
against all odds 09-28-2012 11:03 PM
i don't have a problem with Rich Christiansen. What i have a problem with is the starting line negotiation b.s. and whole "you have to run all out." Yet you can't "go too fast."
vinniekq2 09-28-2012 11:28 PM
pinks was a staged pile of unbelievable crap.I would rather watch fast and furious...
to clear up my specs posted,one was for the older style engines using a 400 block,the other is obviously an LS,though it is possible to use a 3.875 crank in some 4 inch bore 350s,usually they end up as 396/401s with a 30 or 60 over bore
chris78 09-28-2012 11:39 PM
just wondering about the motor thought it might be something different to build and something that no one else at the track would have.probaly just build a 383 or go big block.if a go 383 would love to build it with 6in rods but may not have the extra money.anyone know how much less power the motor would make with just the 5.7s in it.
vinniekq2 09-28-2012 11:53 PM
remember making more power also requires better more expensive parts. The most power for the least money has issues,,reliability and or drive ability.some compromises are acceptable or forced. decide what product you need"THEN" decide the route to take.
IE: a 454 makes good power reasonable price,but is tough to stuff in an old chevy2 or old vette.In a pick up a 454 is a great idea,,,
an LS motor or similar newer technology is a great upgrade over the old carbed cars but cost more,,, what do you need? what is the priority?
vinniekq2 09-28-2012 11:55 PM
some people use the 400 block because the same cylinder heads can flow more air on the bigger bore.IE nascar 360s have the bigger bore and shorter stroke,more breathing/more RPM=morehorse power at a higher cost
painted jester 09-29-2012 01:43 PM
Money is horse power If your pockets are deep and packed with money! You can build big H.P. but the longevity of the engine is limited The upkeep is time consuming and expensive!!! My drag engines are run on weekends and torn down and redone during the week and run again the next week end. You have the choice to make longevity or outlandish H.P.! Drag and street don't compute you have to build somewhere in between ! It would be ashamed to build a big stroker and have a little high revving 302 or 350 blow your doors off you can get gobs of H.P out of a 350 or gobs of torque out of a stroker ! Or even be real different and De-stroke a big block !!!:thumbup:
A long stroke engine piston speed up and down the cylinder is faster then a short stroke engines piston at exactly the same rpm. and a Stroked engine has more reciprocating wht. Reducing this wgt. costs money and increases H.P.
Jester
chris78 09-30-2012 10:05 PM
I'm wanting to pick my drag car up about a minimum of 3/4 of a second up to 1 1/2 seconds and be able to run a couple of years between freshing it.running about 75 to 100 passes a year.i want to use good quality parts but build it as cheap as possible.i'm mostly running brackets so don't have to be the fastest car but want more power than my motor is making now.
vinniekq2 10-01-2012 03:45 PM
how much power are you making now(how fast are you going,what MPH?) Then you can decide whats required.list of driveline pieces/gearing and weight of car is helpful. Its a lot easier to make a 14 second car go 13s than make a 12 second car go 11s
