anyone heard of or used all-pro heads? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 01-08-2013, 01:32 PM
Project89's Avatar
Originally Posted by oldbogie View Post
Strickly race parts, very good track stuff where the rules allow them. Really intended for direct alcohol injection engines that never see duty off the race track, is that what you need them for?
Bogie
no its not this car im building is going to see alot of street duty including 300 mile trips to the drag strips and salt flats i refuse to give up the ability to take the car out on a nice day when i want to
more then likley ill stick with the afr 245s as they will make the power im after , but as most of us i was being open to other options to make the power easier
  #17 (permalink)
Old 01-08-2013, 01:39 PM
vinniekq2's Avatar
use the correct head for the application.If 245 AFR heads are what you need then use them.You know what happens if you use heads that are too large
  #18 (permalink)
Old 01-08-2013, 05:47 PM
Project89's Avatar
while the afr 245's will work great im sure i could get 1,700 hp out of them, i was just looking for other options and cost.
say it takes 30 psi of boost to make 1,700 hp with the afrs , another head might only take 22psi to make 1,700 hp
its really not about picking a set of heads alone , i need to pick a set of heads and turbochargers that will be most efficiant together at my horse power goal
ive been going over alot of heads and turbo compressor maps latley trying to come up with the most efficiant combination of parts to put down 1,500 hp reliably
  #19 (permalink)
Old 01-08-2013, 06:02 PM
vinniekq2's Avatar
are you looking at the AFRs out of the box flow numbers? They are C N C ported only. My dart 227s were C N C ported then hand tweaked before the build. I gained 9 CFM over advertised out of the box flow.
If you are using pump gas you will need 400 cfm flow and still need a fair bit of boost
PBM Aluminum strike force heads.. ever heard of em? artillerystevens Engine 9 04-30-2010 07:36 PM
has anyone heard of these heads?? jgh64pkup Engine 10 03-23-2009 03:03 PM
any body heard of pro comp heads for ford small block mustang joe Engine 2 07-10-2007 08:34 PM
anyone heard of Superflow heads swampwillie Engine 5 08-22-2005 10:21 PM
Ever heard of Flow-Pro mufflers? Rubberman2003 Engine 10 02-24-2004 12:54 PM
