Anyone here running pure E-85? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2008, 04:16 PM
Is anyone here running pure E-85? If so what did you to for the full conversion, etc.? Bigger jets in the carb? also, how will it fare on a vehicle made in the late 70's.. in other words what seals, gaskets, fuel lines need to be changed?
Was thinking about converting my truck to run on alkyhaul...
Old 09-14-2008, 07:58 PM
i've got a holley 600 vac. secondary carb.. any suggestions?
Old 09-14-2008, 11:12 PM
e85 is usually a mixture of around 85% ethanol and 15% gasoline. You would need a larger fuel system to handle the flow of additional fuel, and all the orifices in the carb need to be enlarged (jets, idle air bleeds, idle feed restrictors, power valve channel restrictors, etc) along with new metering blocks for the larger well passages.
Everyone says the fuel system needs to be altered because its corrosive, but there are plenty of people running it on their stock fuel systems for years with no problems.
Old 09-14-2008, 11:20 PM
I believe some people get ethanol and methanol mixed up.. the latter being the most corrosive...
Old 09-15-2008, 01:13 AM
Alaskan Assassin's Avatar
America-Home of the $700B Bail
E85 is pretty corrosive, too. Was going to set my 1991 Pontiac Grand Prix up for E85, turned out to be pretty costly and ended up quitting, and now it's in a pretty poor state ( I loved that car ) Replaced the injectors once, somehow managed to mess up three ignition coils (???) and clogged up the EGR valve. Somehow all the parts associated with this car are more expensive than the parts of other cars I've had...
I was told it pretty much acted as a solvent in my fuel system but got plugged up in the injectors. Though this came from a mechanic who's lost any trust I had. I won't mention what else he said needed to be replaced nor how much he was going to charge me to do it.
I believe e85 can have negative effects on magnesium and aluminum, maybe a few others I can't think of right now. Supposedly it being biodegradable in water causes it to retain more water, which would make rust from water more of a concern that corrosion due to the ethanol. Not sure, I'm just learning about all this stuff myself.
What darkostoj said about enlarging is right, I had a chart somewhere that had a list of suggested jets and other things for changing to e85. If I find it I'll let you know...
If your planning on making your own alcohol you have to start at with 100%, and mix that with the fuel. Buying 95% alcohol will still have 5% water (that, and the cost would gouge your wallet) Saw an article about someone who was selling stills to make fuel with, I believe they ran about $10,000 but the cost to produce a gallon of fuel was below a dollar I think. Of course there was some catch about some poisonive additive to make it legal, no drinking this stuff.
Hope some of this helps, and hope if I'm wrong about something someone will correct me.
Old 09-15-2008, 07:12 AM
i did forget to mention that it would clean all the gunk out of your fuel system and run it through your motor if you have an older tank/lines/etc.
Old 09-15-2008, 12:45 PM
e85
Here's the best E85 thread I have ran across on the net so far.... Its on the Volvo msg board Turbobricks.com. Very good read! Has alot of information on converting fuel injection especially!!
http://forums.turbobricks.com/showthread.php?t=73061
Old 09-15-2008, 12:53 PM
coil packs
Alaskan: what you said about your GP's coil packs threw up a red flag for me.. After running 50/50 e85/gas in my volvo for a few tanks I have a coil pack that is starting to cut out sometimes now.. (maybe the ecu is trying to throw too much spark to the coil packs? or too much dwell? or it could be coincidence but....) seems weird anyway.... anyone else have any experiences with the white lightning?
1974 Pinto w/ 39k miles... won't stay running. ViperMonster800 Engine 32 04-20-2006 09:09 PM
400 Sbc running warm or not? 84KYSS Engine 16 11-16-2005 05:46 AM
ReAssembled Engine Making Noise Not Running Right HELP!!! 71gtx Engine 5 10-10-2005 05:59 PM
Running better with alternator disconnected? lluciano77 Electrical 8 02-08-2004 08:01 PM
Running Boards toolmansson Body - Exterior 3 05-08-2002 05:05 PM
