an anyone identify these heads??
great pics
Thats all I wanted to say!
They appear to be a standard 23 degree head so a small block Chevy valve length will work unless you're looking at throwing a lot of lift at it then you could go +.100. Do you have a cam yet?
BSE Racing Engines |
surely there length could effect the installed spring heights & possible rocker geometry ? |
More radical hot street/strip to race:
Usually if going with .550" lift or more I go for the +.100" valves as the larger diameter dual valve springs used, want this. 1.80" +/- ish installed height. Most street perf hyd flat tappets and moderate street-strip solids: If you will be using stock diameter hi perf springs 1.25" +/- and modest .530" or less valve lift (typical 1.70 to 1.75" installed height) a standard stock length valve gets it done. What cam is being used? what max rpm? |
the cam in my motor is a sum-1102 , but having talked over options in another thread I may look at the 1103 or 1788 cam for my build if I fit these. max rpm 5- 5.5k while im thinking about it as anyone used the sum-1788 cam? |
| Help me identify these heads SB350 | jevonniespapi | Engine | 3 | 05-22-2009 01:42 PM |
| Holley Aluminum heads:Help Identify | QtrWavDave | Engine | 3 | 10-05-2008 12:44 PM |
| Identify these heads please | mustang662+2 | Engine | 12 | 08-21-2007 07:18 PM |
| Identify These Heads? | 1980 Malibu | Engine | 3 | 07-27-2004 10:33 PM |
| 351 4V...how can you identify 4V heads? | servant70131 | Engine | 4 | 04-28-2003 08:11 AM |
