anyone install a hyd clutch cable 302/T-5
hi guy's, still trying to figuer out how Im going to put the t-5 manual trans in to my 54 ford pick up. I have a 54 ford pick up with a 86 302 engine and an AOD trans. Ive determined that Its going to be a monumental task but I really want to do this.
Parts: From Ford Racing, t-5 trans bell housing &block plate hyd TO bearing kit 10 1/2 disc and pressure plate. Cpp brake and clutch pedal assy. clutch master cylinder. Bucket seats modified my driveline Those are probably all my hard parts. I currently have a CPP power brake and master cyl firewall mounted unit which I will have to relocate to make room for the clutch cylinder. CPP told me the new brake and clutch pedal assy will work with some minor modifications. The T-5 from ford is rated for 300 ft lbs of torque and im not into racing so I really shouldn't have any problems there.. If anyone has done something similar I would really like to here from you and any help would be appreciated. Bill |
I have used the clutch master cylinder from a jeep Cherokee..and on that TO bearing there is a tool from sppedway to set the TO bearing to the proper throw..
This item makes life much easier" Hydraulic Release Bearing Set-Up Tool - Speedway Motors, America's Oldest Speed Shop Sam
| hyd. clutch install need help | ashtray455 | Transmission - Rearend | 0 | 07-13-2012 06:07 PM |
| Do I need a stop for my hyd clutch? | Mike Britton | Transmission - Rearend | 5 | 11-13-2006 07:25 AM |
| Hyd clutch | 1963duce100 | Transmission - Rearend | 1 | 02-15-2005 11:28 AM |
| Bellcrank or Hyd Clutch? | 6t6novass | Transmission - Rearend | 1 | 06-10-2004 10:25 AM |
| hyd clutch | 2112jb | Transmission - Rearend | 4 | 04-29-2004 06:19 PM |
