anyone know of a good carb conversion kit??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2008, 06:01 PM
i have a 94 lt1 motor without the wiring harness, im looking to switch to carb, simply because of the expense of a wiring harness that will work with my motor and my 280zx. any one that knows of a good kit please help, or if you know of a cheap harness please lemme know where i can find either of the two. thanks.
Old 05-30-2008, 02:32 AM
280 carb
Early 260 & 280's had carb's find a junk yard and have fun.....
Old 06-01-2008, 02:18 AM
GM makes a carb intake for the LT1 motor. You have to have a few other parts, too. You replace the stub oil pump drive with a regular distributor. You need a plug (also from GM) for where the Optispark distributor used to go in the front cover, and a balancer from a Gen-1 350 (6.75") with a keyway (and a key).
http://www.sdparts.com/product/24502...keSBChevy.aspx
Might be some other stuff that I can't remember right off hand. Mike Mavrigian's book on LT1/LT4 motors has the info, although it's scattered throughout the book.
http://www.amazon.ca/Rebuild-Small-B.../dp/1557883939
Old 06-04-2008, 12:25 PM
MI2600's Avatar
Member# 3287
Edelbrock was making the manifolds.
Old 06-05-2008, 12:56 PM
thanks for
Old 06-05-2008, 12:57 PM
thanks for the help
Old 06-05-2008, 12:59 PM
thanks for the help, i went and ordered that book. its been really helpful. thanks alot.
Carter AFB Carb Good or Bad? 67 sleeper Engine 20 06-24-2009 10:13 PM
A GOOD Portable tool kit??? Rob Keller Garage - Tools 21 12-23-2007 07:02 PM
Disc brake conversion kit Nichols6 Suspension - Brakes - Steering 3 11-22-2007 11:01 PM
Good T-350 rebuild kit? 6426yy Transmission - Rearend 4 09-16-2006 04:30 AM
Stick shift conversion kit cvc505 Transmission - Rearend 1 08-16-2002 09:43 PM
