Anyone know how to install 39 door glass in a 40 ford tudor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2010, 11:16 AM
I have a 40 tudor sedan and I have 39 door glass. I don't know how to install the glass in the 40. Is there any links or pictures, etc. to show me how to do that?
Thanks!
Old 10-21-2010, 12:00 PM
35terraplane's Avatar
39 door glass in 40 tudor
Is the 39 glass one piece or does it have a wing window. Is the 39 out of a tudor. Have you measured both pieces of glass to see that they are the same. I believe what you are tring to do is get rid of the wing window, and save some money by useing the 39 glass. I have had at least 6 40 Fords over the years, but don't rember much about the windows. I think The 39 glass went back a little before it went down, if that was what it did, and it was because of the solid glass you might have to put in the whole works, and not just the glass. I would think about putting new glass in it, that old glass won't be as clear as new glass because of age. I have sock glass in my 46, and the glass looked great, until I had to replace one , boy what a difference. I'm going to replace all my glass now. Check the size out and lrt me know if the 39 doesn't have the wing window. It will work if they are the same size, it's just what you have to use to get it up and down, If you are useing power windows then you just have to put the unit in, in the right place .
35terraplane
Old 10-21-2010, 12:26 PM
The two door door is longer, thus the glass is longer. I believe the 39 regulator is different and the 40 door would have to have some modification done to use the glass if you had a four door glass.
The 39 had a deep vertical channel that the glass slid back to create a "vent" at the front. (1934-1939 Fords used this design)
Old 10-21-2010, 01:02 PM
39 door glass
Brian You are right on the regulator, But did you start rolling down the window to get that gap, or did you go passed closed to get it.
Bob
Old 10-21-2010, 01:08 PM
It was 30 years ago when I built that car, don't do this to me. I don't remember.
Old 10-21-2010, 01:19 PM
39 door glass
Thats why I asked, I think you had to go passed closed. But I think the window came back a little when you rolled it down. That could be my terraplane though, now I will have to walk out to the shop and see. My 33 has power so that won't help, oh well thanks
Old 10-21-2010, 02:11 PM
Conrad_AZ's Avatar
Ya Gotta Drive Them!
Last journal entry: Moved...
On the '39 Tudor, the door window moves back, then down as you crank it down. The rear windows move back about 2" when you crank it up past close.
Due to the length of the 39 window glass, I am pretty sure you would need to use 39 window regulators instead of the '40 ones. You might also want to look at getting a set of '39 window moldings as well.
Old 10-21-2010, 02:33 PM
I'm thinking by the time all the dust dies you would be better off to just put 39 doors on it! I believe the door around the vent wing has some change to it as well.
Old 10-21-2010, 03:05 PM
39 glass in forty ford
Iagree with both. I would still use new glass instead of the old.
Bob
weight of a '39 Ford Tudor sedan sandman351 General Rodding Tech 1 06-06-2004 07:48 PM
'39 Ford rear parallel leafs sandman351 Suspension - Brakes - Steering 2 05-13-2004 07:38 PM
'40 Ford Windshield suede71 Body - Exterior 2 08-10-2003 01:29 PM
40 Ford Tudor rear window regulators Tooch Body - Exterior 1 03-12-2002 10:30 AM
39 & 40 Ford body? Gene Boyd Body - Exterior 1 03-01-2002 04:17 PM
