anyone know how to install a shock tower patch for a 65 mustang?
Howdy!
I need to install a shock tower patch between the frame rail and shcock tower just below the upper A arm. do I just sit it on top of the frame rail and weld in OR since the top of the frame rail has been corroded with a hole in it measuing about 3 inces long and nearly as wide as the frame rail, do I cut out bad metal and use the patch as re-enforcement. (this is what I think needs to be done) Thanks for yalls help on this! |
Always cut out bad metal and fit patch in correctly.You are trying to get rid of rust and return strength not just cover rust.I went a different route on my daughters 66 Mustang. We put in a Mustang II front suspension and got rid of the shock towers. It really cleans up under the hood and you get rack and pinion steering.
Thanks for the fast reply (and the nudge)!
gettin the sawzall out to clear out the old metal. |
on my 68 cougar it wasn't quiet as bad , i welded in the rusted holes. i then added the reinforcement on top of the rail on an angle to the shock tower.
| 65 Mustang hood ornament | cybercat133 | Body - Exterior | 3 | 01-29-2006 09:50 AM |
| Shock tower removal on 66 Nova, help! | frankenvette | Suspension - Brakes - Steering | 2 | 07-06-2004 05:48 AM |
| 65 mustang rearend | tonylsg | Transmission - Rearend | 5 | 04-12-2003 10:40 AM |
| Draglink for '65 mustang | BstMech | Suspension - Brakes - Steering | 5 | 12-03-2002 12:22 PM |
| what engine for a 65 mustang fastback | duckhunter917 | Engine | 10 | 10-15-2002 02:38 PM |
