Anyone know how to remove pinstripes? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2009, 10:17 AM
roddinron's Avatar
I have a 39 pontiac with base coat clear coat paint. About 5 years ago I had a guy pinstripe it using one shot enamel. I'd like to remove them now, without destroying the paint underneath. I had a pinstriper tell me to use easy off oven cleaner, but that sounds a bit harsh, anybody got any suggestions?
Old 05-09-2009, 10:53 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
The oven cleaner will work . As long as it dont have clear shot over it. I have used it on a truck i had it didnt hurt anything on mine. Its not good on anything plastic . Im sure there is a better way im like you oven cleaner does sound alittle harsh but it does work. http://www.poffworld.com/Pinstripe.html . Cole
Old 05-09-2009, 11:13 AM
eloc431962's Avatar
Wiki Edits: 37
I have also seen people wet sand with real fine sandpaper then buff it back to shine. Cole
Old 05-09-2009, 12:38 PM
buggmann's Avatar
build it like you like them
Last journal entry: buggmann stilling looking
Wiki Edits: 2
buggmann
hey what about the wheels they use
to take off the glue off when you take
off emblems off cars my dad used one
when her took the emblems off has ford truck
they worked good and did not mess the paint at all
and it worked well
Old 05-09-2009, 01:38 PM
I couldn't imagine in a million friggin years spraying oven cleaner on your car! I know, I know, I have never tried it, but you know I am going to now! I'll do a little test on something from the metal bin, but I'd be damn if I would spray it on my street rod.
The eraser wheel won't work, that is a whole different story and it would do NOTHING.
The first thing I would do is try in an inconspicuous place a "solvent rub" test with a rag and lacquer thinner. This is a standard test for 2K products. If it softens the product being it primer, SS paint or clear that you are testing, then it isn't a real "2K" or it wasn't catalyzed properly.
In your case, if the clear is a urethane clear basecoat clear coat paint job that test should do nothing what so ever to the clear. If this is the case and the stripe is regular old "One Shot" as most stripers use, it ISN'T a "2K" and is not "cured" but merely dried. It will come off with the lacquer thinner on a rag.
Sanding it off is dangerous because it is so easy to sand the surrounding clear AS MUCH as the stripe. In other words you sand thru the clear BEFORE you sand the stripe off!!!
This can be done of course by using a block and being careful to ONLY sand the stripe. But the learning curve is pretty painful.
Also, there is a good chance that when you remove that stripe, you will be able to see where it was! Even though that clear may be a 2K you are asking a lot to run a stripe full of solvent over it without it biting in a little.
I have seen many times where when the stripe is carefully removed you can still see a "ghost" stripe there.
Old 05-09-2009, 02:54 PM
eloc431962's Avatar
Wiki Edits: 37
Brian is right. I wouldnt spray it on my streetrod either but i did use it on a 97 ford i had that had painted pin strips all over it and it did remove it didnt hurt the paint seems like there was a little haze though and there was the dreaded GHOST STRIPE. It was still there. I have heard 3M has something to remove pinstriping with but i have never used it.myself i would leave it or repaint it. If it has clear over it no spray is gonna work anyway. Cole
Old 05-09-2009, 05:33 PM
roddinron's Avatar
There's no clear over the stripes. I tried removing them from the headlights using 1500 grit emery, but it did screw up the clear coat. I tried soaking them and rubbing them with lacquer thinner, but it didn't take them off either, just made them dull. I may still resort to the oven cleaner, I just know how these things go, you start out trying to remove a stripe and end up repainting the whole car!
Old 05-09-2009, 07:22 PM
eloc431962's Avatar
Wiki Edits: 37
If you do resort to oven cleaner apply it with a cuetip just on the pinstriping. And let it soak for a while then wipe it off. Thats how i did. Whatever you do dont just spray it on.. Cole
Old 05-09-2009, 07:43 PM
roddinron's Avatar
Thanks, good advice, the Q-tip sounds like the way to go.
Old 05-09-2009, 09:09 PM
milo's Avatar
point on positive
+1 on Easy Off , (with the blue cap) It may leave a ghost so be advised...
Old 05-09-2009, 09:45 PM
roddinron's Avatar
thanks guys.
Loose Gm Tilt Steering Wheel Moves Up And Down fumplet Suspension - Brakes - Steering 10 05-13-2012 06:07 PM
1999 Jeep Cherokee Rear Axle Seals - Help leejoy Transmission - Rearend 2 05-15-2007 07:50 PM
Using a Grinder to remove paint duallybuster Body - Exterior 16 07-30-2006 10:17 AM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
C6 Installation Trucknut Transmission - Rearend 6 01-18-2006 05:01 AM
