Anyone know if all 28 spline 9" posi are interchangeable - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2012, 08:39 AM
I have an early 59 rancharo 9" in my 63 Fairlane and have access to a 78 LTD II (sport) 9" posi/limited slip rear both 28 spline. Will the posi work???
Thanks
Old 09-21-2012, 10:55 AM
big gear head's Avatar
High Performance Rear Ends
Yes it will. Just be sure that the '78 is actually a 9 inch. You might want to install new clutches in the Traction Lock before you install it. Every one of these that I have disassemlbed had worn out clutches.
Old 09-21-2012, 05:24 PM
OK thanks for the info!
Old 09-21-2012, 10:04 PM
Wiki Edits: 27
9 3/8 ford.
Ford made a 9 3/8 rear, most commonly used in lincolns, big fords. one of the reinforcing ribs is curved, hockey stick shaped.
Old 09-21-2012, 10:26 PM
Yea, but all of the 9 3/8 rear ends had 31 spline axles. A 9 3/8 chunk will work in a 9 inch housing if you grind a little clearance for the ring gear to pass through.
trying to find 8.5 ten bolt 28 spline posi ken konoff Transmission - Rearend 10 01-01-2010 07:28 PM
Change Ford 9" - 28 spline to 31 spline fredbaker Transmission - Rearend 5 09-27-2009 05:12 PM
what axle spline is a posi? fordsucks7 Transmission - Rearend 3 04-08-2009 10:49 AM
GM 7.5 posi 26 spline 2 series Locking Diff 383MontecarloSS Transmission - Rearend 10 04-05-2004 07:35 PM
30 spline posi unit..what axles? 383MontecarloSS Transmission - Rearend 3 03-09-2004 01:36 PM
