Anyone know the stock compression ratio for a 1979 350 chevy ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2012, 10:35 AM
it came out of a truck and as far as i've researched it had 175 hp and 250tq back in the day, previous owner said it is completely stock, does anyone know the compression ratio that came in this engine ? or perhaps the cc's of the pistons
I'm trying to get an accurate compression estimate because i just bought a set of 305 cylinder heads 601 casting which have been ported and machined to have 58cc chambers and 2.02 intake and 1.60 exhaust valves
the engine has a slightly more aggressive than stock cam and i'm hoping for a tad bit under 9:5:1 compression so i can run 89 octane
Old 06-05-2012, 10:40 AM
Madmax305's Avatar
I don't know exactly, but you can figure in the 8.5-9.0 compression ratio.
Old 06-05-2012, 05:23 PM
If its stock, then not more than 8.5.
If you measure it you may find some engines calculate out as low as 8.1.
Bruce
Old 06-05-2012, 06:09 PM
GMCBEAST's Avatar
I agree with above, 8-8.5:1. Those 76cc heads (Most likely what you have) kill compression, throw in a dished piston and you end up on the low end of the C.R. ladder. On the good side you don't need premium gas. If they are dished pistons I think they are 18cc cups, I'm not positive though, 58cc chambers are ok with dished or most 4 valve relief flat tops but you need to pay close attention to your timing with the flat tops. Summit and Wallace Racing have a compression ratio calculator on their site's once you figure out your specs. Hope this helps.
Old 06-11-2012, 02:29 PM
78novaman's Avatar
The AMC, FORD, & CHEVY Guy??!!
Last wiki edit: Improving fuel economy
Last journal entry: Finally on the road
According to my Hayne's manual:
8.2:1 for light duty trucks
8.3:1 for heavy duty trucks
All I can think is maybe slightly different pistons???
Old 06-11-2012, 09:31 PM
My Firebird with a 305 is at 8.5 right now stock, yours should be in the same relm
compression ratio on 350 chevy dar100e Hotrodding Basics 2 03-23-2011 12:44 PM
compression ratio of a stock 96-00 vortec engine?? redfish211 Engine 24 02-22-2011 07:56 PM
Pontiac 350 compression ratio? AndersonRacing44 Engine 3 07-21-2010 08:51 AM
stock compression on sbc chevy 302 327 or 350 dustinweaver Engine 5 04-07-2006 10:11 PM
compression ratio for a 350 sbc??? classic_chevy_guy Engine 6 10-27-2003 11:44 AM
