Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Anyone know washing machines?
Old 11-04-2012, 10:06 AM
boatbob2 boatbob2 is offline
boatbob2
Hi,i took the outlet hose from my washer,and inserted it into a piece of PVC,then ran it thru the wall to the back yard,probably 15 feet,then i got a fitting to make a T,then used 2 -5 ft long pieces,capped on one end,then drilled 5/16 holes every 4 inches on these 2 pieces,glued everything together,EXCEPT,the straight leg of PVC,so i could occasionally remove end so i could wash out the lint,saved my septic tank,and watered the grass at the same time...
