Ok Jester you have me thinking........you are talking the vents that go up to the roof? I don't believe there is one on this portion of the system. And my hose from the washer does go into the drain pipe tight, hmmmmmm. How did you add the vent to the washer?
A pcv 45T (and another to make the pipe plum) at the washer pcv pipe going up to the ceiling about a foot down from where the washer hose enters! But if its not the problem and it plugs it could rise in the vent and come out ! My home is vented and goes into a septic but my washer and kitchen sink goes into a dry well and grease trap so they needed the venting I should have run it out the ceiling but was lazy and the 4 extra feet worked fine you could install a one way valve so air can go in the vent but water cant come out and then seal the washer drain tube to the pcv so it cant leak again!
Jester
I sure hope this helps its agrivating!
Ive been there
Man that 175 dollar filter sure looks easy to make and a woman's nylon sock fastened to the inlet inside could catch the lint!!!
