anyone know why wrist pin offset is important? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2003, 09:34 AM
57Waygone's Avatar
New Member
Thanks for any information you can supply.
Ron
Old 11-25-2003, 10:28 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
Supposed to keep the pistons from rattling by pushing them to the side of the cylinder.
Troy
Old 11-27-2003, 11:09 AM
Sandflea427SS's Avatar
Anything with a throttle
Turning the pistons around is an old moon shiner trick according to Smokey Yunick. Smokey went as far as producing "math" that
calculated the maximum distance to offset the wrist pin to produce the maximum amount of HP gain. In the article, he mentions that with "modern" technology, the car companies didn't offset the wristpin anymore. He said in the old days, you could just install the piston "backwards" and get more HP. He felt that piston makers should offer offset pistons for race car. He did say said if you bought enough you should be able to get your
piston maker to do this. He indicated that every winston cup team did this.
Smokey said you might get a little bit more wear on the piston skirt and a little bit more noise. I can't tell any difference on engines that have this treatment. You certainly can't with a header. The piston will "travel" a small amount extra so you have to be carefull about valve openings and deck heights.
Old 11-27-2003, 11:55 AM
BOBCRMAN@aol.com's Avatar
In a hotrod motor pin offset is not usually an issue. The OEM builders do this for cold piston noise controll on cast pistons. I have built long rod 400's and 383 street motors where installing a street cast piston backwards helped with internal clearances. Smokey and a few other old time engine builders say it also improves rod angle and torque output. Forged racing pistons usually have a centered pin as they are noisy anyway.
One of GM's biggest warranty problems now is the short skirt, minimal offset pistons they are running in the new cars. I change many sets of these each week. They are replacing them with a tighter fit piston and coated skirts. New car customers don't like that rattle in the otherwise silent (except for belt noise) powerplant when first started cold.
