Originally Posted by ap72
MS1 has been used in many engines over 500hp. And it is the slowest of the bunch. The calculations are the same for 15hp or for 150hp per cylinder, the power is irrelevant.
really, the time at 1000rpm and the time at 7500rpm are not anywhere near the same
You can run 4 sequential channels on a MS2 system, meaning your sbc will have "semi-sequential" injection if you're running 8 injectors (2 injectors per channel). It comes down to the number of channels, you can have 4 on a MS2, 8 on a MS3.[
as seen as we are talking about a v8.. that means the MSII doesn't do sequential injection.. it has BATCH..
and because it can't do 8 seperate sets of caculations to do sequential injection on the v8 ir a v6 or v10 or a v12.. then it's not FAST enough, the ecu BRAIN isn't powerfull enough..
"semi senquential" isn't senquential unless oyu have a 4 cyl .. when was the last time you saw a 4cyl vette?
and this is why I haven't bought a ms system yet, to many LIE about what it can or can't do..
semi sequenial.. isn't sequential..and never will be.. the reason it doesn't have the "resalution, is the ecu CAN't handle the caculations needed"
it's like dial up and highspeed internet..
AGAIN speed and power HAS EVERYTHING TO DO WITH IT>>
