Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Anyone making big power with Cheap EFI setup
  #46 (permalink)
Old 10-17-2012, 07:25 PM
E.Furgal E.Furgal is offline
Last journal entry: was hoping for better than this
Originally Posted by ap72 View Post
I don't need to, I had a Jetronic system on my L28 before I switched to MS1, still running the original injectors and coolant sensor. Furthermore I own one of the "how to tune Bosch Jetronic" books no longer in print.
looks like it maybe electronic but not computercontrolled.. as we think of it today
"Analog fuel injection. The 'D' is an abbreviation from German: "Druck", which means pressure. The depression (vacuum) is measured using a pressure sensor located in the intake manifold, in order to calculate the duration of the fuel injection pulses. Originally, this system was just called Jetronic, but the name D-Jetronic was later created as a retronym to distinguish it from the newer versions."
