Originally Posted by hcompton
i believe you but wasnt looking for something to run off tables want to use wide band and have it adjust. You are doing table swaping so it kind of fakes it but its not fixing it on the fly. I can do static tables with stock gm ecu. I understand your system works great for you bit i am still leaning toward ms3 and some goodies to go with it. Still should be close to my 1000 price tag.
you can't run any system entirely off of wideband, or it will always be lagging behind. You need static tables to give you a good first guess from which your sensor can then adjust the pulse depending on what reading your getting. Under acceleration it'll always be way off, under cruise it'll be close to optimal as you're running a fairly steady cycle.
