Anyone ran the Performer RPM cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2005, 11:58 PM
Hey i guys im looking into getting a performer rpm cam and wanted to know any likes or dislikes. My motor is a factory roller motor 87+ and was looking to use part #2204 which the specs are 234int/238ext at .050 and .539int and .548ext 112* lobe sep and 107* int centerline. My car is carbed and was wondering if this cam is going to be lopey?
Old 03-17-2005, 05:12 AM
edge's Avatar
Time is short, are you ready?
Yes it will be lopey, but it is awesome. I ran the flat tappet Performer RPM cam in a 355 with their RPM heads and a Pro-Flo fuel injection and loved it. Now I have their Performer RPM hyd roller cam in my 385 with AFR 195 heads and Pro-Flo fuel injection and it is even better, as it should be. My engine description can be seen here.
Bottom line, I love that cam and would highly recommend it; if your engine combination and car setup (ex. converter) warrant that big of a cam. Also, I did not check your stated part number, but be sure it is not a retro-fit cam, but designed for a factory roller block.
Good luck, Ed www.edgesz28.com
Did You Know?
Old 03-17-2005, 06:04 AM
Last journal entry: PICTURE TEST
cam
I have run the no-name brand of the exact cam in my own personal engine plus have used it in a few customers engines and i like them. They are about the edge for a daily driver IMO. The only thing i would suggest is to determine your static compression before you buy the cam. It really should be 9.3/9.5 or higher for this cam to work well...
Keith
Old 03-17-2005, 06:08 AM
cboy's Avatar
Last journal entry: Finished
Hey Edge,
Not to hijack the thread, but do you do something special to get your links and web site to show up as a hyperlink? Recently, when I've put a site address in a post...it just comes up as the address (which has to be cut and pasted) rather than automatically changing to a hyperlink.
Always learning...and sharing what I've learned.
Old 03-17-2005, 06:17 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Insert hyperlink
Just above the screen wher eone types a reply there are some symbols for bold, italic, underline, create list, insert hyperlink insert e-mail. and wrap quote..
I got enlightend on this a few days ago..
OMT
Old 03-17-2005, 08:51 AM
Heres all the specs
87 Formula Firebird 355 4bolt main 92 block factory roller
9.5:1 compression
Factory swirl port heads that are ported soon will be performer rpm heads or a set of 23* trick flows
Edelbrock performer RPM intake
Hooker super comp shorty headers
Full 3 inch exhaust all the way back about to upgrade to true duals or a single 4 inch mufflex set up.
Full msd setup
Have 2 carbs going to try both to see which it likes i have a 670 street avenger and a 750dp
5 speed manual
3.73 gears
The car currently has a comp XE262HR and falls on its face at about 4,500-5000 and has a smooth idle. It bugs me i want to sound mean and be able to pull into some higher rpm's. The most i plan to spin it is 6,000-6,500 rpms.
How much does it normally cost to get a set of heads done to hold this cam. My heads are only setup to about .480 lift?
Old 03-17-2005, 08:53 AM
Also plan to hook up a 150 shot to it anyone ran bottle with this cam does it like it?
Old 03-17-2005, 09:27 AM
1964chevelle's Avatar
its not pink its ember red
i have this cam in my 327 i love it because its just right for the high rev of the 327 i has pretty good pickup but i have a 3500 stall on the street so i have to down shift if i wanna go fast. It has a great idle for the street and it scares the hell outta those honda cars when i pull up
Old 03-17-2005, 10:56 AM
edge's Avatar
Originally Posted by 1964chevelle
It has a great idle for the street ...
With my setup, I get about 10" vacuum in drive, but I do idle it about 925-950 RPM. With a 2800 stall, it is fine.
cboy, do the hyperlinks link OMT said. But if you really want to get slick, do it like this:
Click on the image
Ed
Old 03-17-2005, 11:12 AM
Siggy_Freud's Avatar
Heres all the specs
When it comes to choosing new heads, despite having the Edelbrock RPM cam and intake, I'd go with some Trickflow 195's. I am not just saying this because I have them and love them . . . but the Edelbrock set has a much smaller intake runner and exhaust runner. While this will help keep velocity and lower end power up, it doesn't leave much room for expansion, and I think the trickflows would mesh better with your intended cam. The trickflows I have accept up to .54 lift. Standard is .52 I think, and they offer them up to .60 for a few bucks more. I went with the middle group and wish I had gone with the upper group just for upgrade purposes.
BTW edge I never really realized that you had such a meaty setup along with your TPI project. Nicely done
Old 03-18-2005, 02:55 PM
edge's Avatar
Click on each image to see/hear some videos - #1 is 1,460 KB & #2 is 1,157 KB: WMV format
In the idling video, again it is set at about 925-950 RPM in drive. This works very good with the Performer RPM cam (either flat tappet or hyd. roller). The throttle response on this cam is nothing short of awesome. The nice thing about fuel injection is you can run a higher idle and not worry about run-on when you turn off the engine.
Now, before you doubt the power, keep in mind that this was off idle and in my driveway. I cracked it about 3/4 throttle and let off rather quickly. I am planning a couple of trips to the track this spring, so we will see what she's really got
Ed
EDIT: Sound cards vary by computer, but if you have a decent card, my car will give you a good idea of what a pair of 3" Flowmaster 50 Series Delta-Flow mufflers with tailpipes sounds like.
Old 03-18-2005, 04:11 PM
spinn's Avatar
man thats awesome! i want to take some burnout footage of my ride !
Old 03-18-2005, 07:22 PM
Sounds great. I really like the way the whole cars jumps in the air when you hit it. I would like to hear how it sounds at 50 to 100 rpm lower at idle might have more thump. How do you get the video and sound clips on here? I would like to try that some time.
Old 03-18-2005, 08:14 PM
I dont know if you missed but im not fuel injected any more im carbed. Also i have a 5 speed manual so im not worried about it being a fairly big cam plus i have 3.73's so ought wake up with having a better cam in it. I went ahead and bought the Performer RPM roller cam. Got a question about how much would it cost to have a machine shop set my heads up for a .540 lift cam? Im kind of short on change and cant throw out enough money to buy a set of heads right now. So i got to make do with what i got. I was also thinking about cleaning up the ports some while i have them off and maybe gasket matching them. But anyways what do you think the machine shop will charge 200-300?
Old 03-18-2005, 08:19 PM
With as big of cam this is it should have a pretty healthy lope. One of my friends in his S10 with a small block had the XE268 cam and it had a nice lope and thats puney compared to this cam. Im drooling at having some lope. Cant wait i will get some vids up after i do the cam swap.
267 small block chevy chevellecamino Engine 59 02-03-2012 02:04 PM
Cast or hyperutectic pistons Novaman78 Engine 36 02-01-2005 09:25 PM
Raising the Redline Hollywooding Engine 23 07-17-2003 10:19 AM
Performer or RPM ? reddwarf Engine 9 03-02-2003 01:02 AM
Fitting Performer RPM on 76 Vette FredT Engine 5 10-07-2002 04:57 PM
