Anyone run a 352 or 377 SBC ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2007, 10:53 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
I know there is no replacement for displacement.
Heard a lot about the the 352 or 377. Haven't seen one in several years.
Anyone have any input as per useage, power, etc. besides NASCAR?
Certainly the 383 is easier to build, and readily available.
thanks,
x
Old 02-02-2007, 02:52 AM
runn141's Avatar
id like to know too, i have a 400 block i wonder what a 377 would be like on the street?
Old 02-02-2007, 03:10 AM
If I had a good 400 block laying around, I'd try the 352, just so I could say I had a Chevy 352. And also it'd get this dang 307 crank out from under my feet.
Wonder if I could change my fender emblems to say 352???
Old 02-02-2007, 04:12 AM
runn141's Avatar
is the 307 crank journal the same as a 350s?
Old 02-02-2007, 07:28 AM
377"
Yes, I have one in a boat, its a 4 bolt with a CROWER (0024200 cam, 9:5-1 compression, RPM Air gap, 750 Eldebrock, Mallory dist., MSD 6A, early FI. heads that are port matched, bowls and combustion chambers cleaned up and polished, 1:6 roller tipped rockers, and balanced... This motor is brand new, so don't yet know how well it will perform, but it feels good and planes instantly in initial runs to put some time on it...but I have a friend with a 1970 Vette roadster, who built one with a 4-71 blower... IT HAULED !!! ..I understand the advantage is that they will rev due to the shorter stroke, that is why I used it because I am looking for mid range to top end as I can't use the bottom end due to prop size limitations (tire size).... But if you use a blower or NOS you MUST o- ring the block or heads !!!
Old 02-02-2007, 08:01 PM
Yep.........
Old 02-02-2007, 08:16 PM
cabowabo's Avatar
big Q
355 here
heres my 355
Old 02-02-2007, 11:50 PM
xntrik's Avatar
Originally Posted by cabowabo
heres my 355
A 355 and a 352 are two very different animals. Mouse motors that is.....
325, 352, 377 are built on a 400 block. NASCAR uses a 352.
I have never even heard of anybody with a 321/325.
Probably because there are/were no classes with that cube limitations.
3 inch stroke in a 400sbc?
Old 02-03-2007, 08:31 AM
so...to build a 377, u use a 350 crank, 350 rods?, and special pistons or ??
Old 02-03-2007, 02:56 PM
yep
yep, that is what you use, but on mine I only bored it to .020 over, just in case I ever wanted to re-bore because .040 is the safe limit ON A 400 BLOCK..
Old 02-03-2007, 03:05 PM
swvalcon's Avatar
Last journal entry: rust on lt body shell
For your main spacers use a set of 400 .010 bearing and set your 350 mains over them works as good as the aftermarket spacers or the high dollar speical mian bearings.
Old 02-03-2007, 04:07 PM
firestone's Avatar
http://teamrfc.gospelcom.net
I had a 3.295 stroke 4.155 bore 358 (made 608 hp @7900 RPM, 460 ft lbs). I really dont see any benefit to a motor like this in a drag or street car. It ran well for the size, but it would have been faster and more fun to drive if it were a 406. On top of the fact that the 406 would have been faster, it would have been more reliable in that the max RPM would have been less, and there would have been less of a tendency for valvetrain problems.
Adam
Old 02-03-2007, 08:35 PM
352"
Back in the 60's, i had a friend that ran a 55 chev and it ran 10.30 @ 130 on a small block that was a 352" HILBORN injected chev, i know it was stroked with a REATH AUTOMOTIVE" crank ...thats all i remember
Old 02-04-2007, 09:30 PM
xntrik's Avatar
Originally Posted by F-BIRD'88
Nothing speacial about the pistons. Most piston makers supply them. This is the same piston that you use on a 400rebuild if you're using the shorter 5.565" factory 400 rods and 3.75" 400 crank.
3.48" crank 5.7" rods
3.75" crank 5.565" rods piston same same
cubes figured with .030 overbore
377 is 400 block and 350 crank, 3.48
352 is 400 block and 327 crank, 3.25
325 is 400 block and 283/302 crank, 3.00
I keep wondering, Mopar favored short stokes for their popular engines, and still get raves for muscle power. The new 383/400 was 3.38 stroke.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
$4,557.99 for SBC 400 Parts/Machine Work DTL504 Engine 35 04-03-2006 05:36 PM
434 sbc...what fuel system should i run? 68SSMaro Engine 5 05-08-2004 03:10 AM
377 sbc in a truck molevolent_creations Engine 16 01-25-2004 05:09 PM
BEWARE of hidden cost with SBC Yahoo TooMany2count Hotrodders' Lounge 4 01-05-2004 07:32 PM
