Anyone running a Chevy inline? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2008, 07:31 PM
Twisted Minis's Avatar
A different breed
Last journal entry: New Truck
I am running a 250 I6 in my 30 Chevy. I've had no luck finding intakes other than the ones that run a one or two stock single barrel carbs. I have some Holley 94s that I want to run, and I also want to run my own version of a lakes header. Since neither of these manifolds are being made, I plan on building my own. What I am wondering is if anyone else would want something like this? If not a lakes header a traditional, but mostly for running two (or 3) 94s or 97s. Or any other 3 bolt carb. I am basically trying to figure out if I should have some stuff laser cut to make a few, or if I should just focus on making my own and call it good at that.
Old 10-05-2008, 08:06 PM
redlightning's Avatar
If no one knows here,you might try these guys.
http://www.inliners.org/
Old 10-05-2008, 08:47 PM
junior stocker's Avatar
Chevy 6.
There's actually a ton of aftermarket stuff for the 194-215-230-250-292 style 6 cylinder engines. Clifford 6=8, Offenhauser, Fenton (repops), Major Cam Manufacturers, Ignition Components. It does cost a bit more to build than say a SBC. Just what I like to see; another "Six Maniac", or "Registered Six Offender". Build a mild 250 shortblock; use a # 3864883 194 head for the small combustion chambers, HEI distributor, Clifford intake with a small Holley 4 barrel, the repop Fenton cast iron headers, mild hydraulic cam. Back it up with a 3.11 first gear Saginaw 4 speed and 3.55/3.73 rear end gearing. YOU WILL BE IMPRESSED, and DIFFERENT!
Old 10-05-2008, 09:22 PM
A different breed
I realize there is a big aftermarket. It just isn't really what I want. Its an open wheel car, so I want the look of the 2+2 intake and the lake header.
I've got a TH350 and a Ford 9 Inch with 3.00 gears in it to back the motor. I fear I won't have room for 3 pedals in a small car, otherwise I would source a T10 or something similar.
And I will probably run a mild Crane cam.
Old 10-06-2008, 01:14 AM
techinspector1's Avatar
Wiki Edits: 326
Tooooooooo Cool.
32 chevy chassis too short for my 32chevy 4 door 31chevy Suspension - Brakes - Steering 22 05-28-2008 04:14 PM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
Looking for Fiberglaas or Steel Fenders & Running Boards for my '37 Chevy 1/2 ton 37chevytrucker Body - Exterior 3 01-25-2006 02:39 PM
292 Chevy Inline 6 69GMC Engine 6 02-16-2003 10:31 AM
1951 chevy inline 6 intake manifolds lgsteelhead Engine 5 01-07-2003 06:26 PM
