I can tell you what I use is Southern polyurethane epoxy primer and Marson Platinum filler..I have found those products are easy to use..Just Da sand to metal with 80 grit and prime 2 wet coats and you are good to go with your base clear..or whatever you choose for the finish..If you want a great job strip to bare metal..
Sam
