Anyone sell spring bushings by dimension? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2007, 07:55 AM
Last journal entry: Bringing home the 401 Nailhead
I have a 32 Ford w/ 9" Ford. Don't know what year the rear is and don't even know if the leaf springs are Ford. I am trying to find new polyurethane bushings. Everyplace I try list bushings by application. I am trying to find someone that lists by dimension or can cross reference an NRC number.
Here is what I do know:
Large eyelet is 2 inside diameter old bushing is NRC 90385-13065
Small eyelet is 1 inside diameter old bushing is NRC 90885-13071
Old 03-28-2007, 12:17 AM
Take a look at this page
http://www.sor.com/sor/cat289.tam?xa...x=cat289%2Etam
moving rear coil spring location to change rate cboy Suspension - Brakes - Steering 32 03-01-2007 11:31 AM
leaf spring bushings runn141 Suspension - Brakes - Steering 2 12-26-2006 10:50 AM
Redoing 74 Nova Bushings - Initial Planning topdogger Suspension - Brakes - Steering 8 11-13-2006 10:28 AM
Mustang-II rack & pinion mounting bushings?? NASCAR314 Suspension - Brakes - Steering 4 02-08-2005 12:53 PM
Proper throttle spring placement willys36@aol.com Engine 1 11-13-2002 07:19 PM
