Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Anyone tell me what engine & tranny this is?
Old 10-28-2012, 06:50 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
Hey Carlos...it does look like a small block Chevy 350...If you buy header gaskets for a 79 350 you should be OK...As far as transmission I think Dexron 11 should do it for you...Check the bolt pattern on your trans oil pan that will tell you what type it is. You can take a look at it and google 79 GM automatic transmission pan and it will give you the type of trans and information you need,
Ray
