Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Anyone tell me what engine & tranny this is?
  #79 (permalink)
Old 10-30-2012, 05:16 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
OK Carlos, when you add disc brakes to the rear you must use a true 4 wheel disc master cylinder. The pressure and volume requirements to the rear are much greater than that required by drums, disc brakes require more pressure and volume. A four wheel disc master will have a longer stroke and will provide more pressure to the rear disc brakes. So in saying all this, using the master cylinder and brake booster from the Trans Am should solve your braking issues.
