Sorry it took so long to get back to you but I had a meeting that went a little longer than originally thought.
Now your brake situation.
Use a Raybestos MC #39052 (you can get your local parts store to cross this number over to Cardone or Fenco part numbers) and a disc/ disc prop valve on a stock 79 Camaro disc/drum booster. This master is spec'd for a 1980 Corvette not 79, it may cross to the same number. It works and is cost effective.
The proportioning valve used is a PV-4. Check out a valve at your parts store and see if you already have one on your truck(I know you said you weren't sure anymore if it was 79 Camaro). If you have trouble with the PV-4 number working at your parts store let me know and I'll see if I can cross it over.
This should work for you and happy braking.
Let me know how it all works out.
Best Of Luck
Ray
