Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Anyone try Comp Cams Nostalgia Cams ?
Old 11-21-2007, 12:05 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
Comp Cams does a good job of marketing the latest trick of the week flavour cams. Their Thumper rabbit cams are a good example.
The nostalgia serious are modern interpretations of the old factory cams
The 300+ cam grind is a little short on valve lift. Valve lift is good for making torque. (with short/moderate cam duration)
I would look for a similar .050 duration cam with a little more valve lift.
Isky #201264/271-12 or Comp cams #12-208-2 are good.
use a Isky 205D or comp 981 or Lunati 73943 valvespring.
A mild Lunati Voodoo cam like Lunati #60100 or 60101 would work very well also.
