Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Anyone try Comp Cams Nostalgia Cams ?
Old 11-21-2007, 09:39 AM
super_silent's Avatar
super_silent super_silent is offline
Originally Posted by 454C10
Sorry, I haven't used one of those cams. What are the specs?
advertised duration?
duration at 0.050"?
What is the 327's compression ratio?
I would use an old school compcam 268H. Those new high lift flat tappet cams tend to go flat quickly, especially with todays reformulated engine oil. I'll give up a few horses to allow the cam to live longer than a month.
Use diesel engine oil or an EOS additive with your new cam.
The 327 is pretty much stock, it has the camel hump heads on it and I believe the compression ratio is 10 : 1
I've had the quadrajet slightly modified and added a pertonix distributor & coil.
Here are the specs on the Nostalgia cam:
Product SKU: CAM CL12-670-4
HYDRAULIC-Sound of GM 300HP camshaft with improved power and performance.
Intake/Exhaust Lift: 426/420
Intake/Exhaust Adv. Duration: 258/265
RPM Range: 1000-5500
