Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - anyone try the Roper WHitney Jr hole punchers?
Old 01-26-2012, 09:17 PM
tech69 tech69 is offline
put up or shut up
there's also air ones that are convenient but you can't punch them in from the edge very far. Roper xx allows you 3" of depth from the edge. You can always drill the holes but that takes long, warps the panel slightly, and the hole has to be cleaned up of metal shavings and restraightend for optimal welding. So if you find yourself with huge panels where you'll plug weld a lot it becomes a lot of work.
