Anyone with Turbo knowledge please help. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-31-2013, 10:51 AM
hey guys,
i have read a ton of other threads and im sorry to start a new thread that has been done before but a lot of the other ones get side tracked. heres what i have. fresh rebuilt 454 8.5 to 1 cr flat tops bare bones 525@50 lift. 781 heads ported 2.19 1.88 valves gear drive holley 850dp. Im looking to do a single turbo rev to about 5500 to 6000rpm, and make about 600hp or so. its going in a 62 c-10 ... im just looking to keep it simple. im looking for someone to help me out on what turbo is best. the name and size turbo so i can look at prices and start getting things rolling. i know motors just never been around turbos. if some one is willing to take the time to give me a rundown on a entire setup i would appreciate it greatly. if more info is needed from me just let me know. thanks everyone in advance for any help you can give me.
Old 07-31-2013, 11:51 AM
hi , well turbonetics,,, are a very good brand of turbo,
and they hold up well and the bearings in those turbos are awesome,
as far as how big of a turbo, it depends on your camshaft
and engine set up , were do you want to make your peak power,
they sell little to large turbos based on how much rpms it takes
to spool one, there actually a formula for that ill have to look for
but once i find it il post it, also u will need to modify the oil system and ignition timing, and maybe the pistons, what kinda of pistons are you running and are you running a cast crank ?
Old 07-31-2013, 11:57 AM
Try TheTurboForms.com A lot of great info on what your trying to achieve, good knowledge peps as well
Old 07-31-2013, 12:32 PM
Banned
something around a 60mm T4 type turbo will work- there's a few hundred variations of that though. Its hard to say with no specifics. I will say this though, for a street turbo go with just enough compressor to reach your goals and go with a larger than average exhaust side. It'll spool just as fast as the opposite (people often oversize compressors and undersize exhaust in the hopes of having faster spool) but allow you to run lower boost levels to reach your power goal AND give you better mileage.
Old 07-31-2013, 12:53 PM
Project89's Avatar
a single t4 is way to small for a big block
best cheap reliable turbo u could pick up is a garrett tv7512 u can find these on ebay rebuilt for around 300 bucks
they measure
76mm/102mm ind exd compressor
and most are
99mm/86mm turbine wheels
they are t6 flanged and come in .96- 1.0 and 1.23 ar turbine housings
another option would be the borg warner s480 , i think theese sell right around 680 bucks brand new last time i looked
just be aware these turbos are massive
this is a bw s480
and here is one of my tv7512's nexto a 2 litter bottle
the downpipes on these are 5 inch but u can reduce them to 4 inch
my size 13 foot nexto one of the turbos
Old 07-31-2013, 01:53 PM
Banned
they measure
and most are
The T4 flange is more than adequate for the volume he will be moving, its somewhat irrelavant if its a big block or a little 4 banger. Also, the T6 is for dual scroll exhaust housings/manifolds.
And those turbos you included are not only massive, but simply way too big and incorrect for the application. He's going for 600hp, not 1,000.
For 600hp a 60mm T4 type is a hair on the small side (though a lot of it depends on the rest of the turbo specs), which will equate to no lag on the street.
Turbos are like cams- bigger may sound better but it just means you'll be making power where you'll never use it.
Old 07-31-2013, 02:08 PM
Project89's Avatar
umm no
a t6 can be had in divided or open turbine , both of my tv7512's are open
the tv7512 is good for about 650ish before u really push it , its perfect for a simple big block build
even if the turbo has a divided housing it can still be run on an open flange it makes no difference
a t4 76 mm turbo will have a much higher backpresure to boost ratio then a 76mm t6 unles su go with one of the much larger turbine housing options
can u do it with a t4 sure u can but why when the t6 flanged unit will give much less backpresure and not choke the motor out if u decide to turn it up
i didn't see were he listed a hp goal the s480 is bigger and capable of more and if thats all he wants then yes its a lil large but the s480 comes in a few different configurations or u can step down to an s400 which would be a good match just like the tv7512
go look at some 60-66mm turbo compressor maps @ 600 hp most will be way outsided there efficiancy range
Old 07-31-2013, 02:28 PM
Project89's Avatar
he didnt mention crank or wheel hp so ill assume wheel for now
if that was crank hp it makes the maps look even worse
61mm t4 turbo with target of 750 crank
62-1
70mm
just want some knowledge badknuckles Hotrodding Basics 1 04-12-2011 04:34 PM
Hi I'm new and value your knowledge!!! wifeseekinginfo Introduce Yourself 2 12-17-2009 02:51 PM
Always Looking For Knowledge...... NUCKINFUTS MTRSPORTS Introduce Yourself 2 03-16-2009 09:31 PM
Too much knowledge here... Kudagra Introduce Yourself 3 10-22-2008 09:20 PM
knowledge fsjimmy Hotrodders' Lounge 0 11-30-2003 11:48 PM
