Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Anyone use this cheap turbine HVLP gun
Old 07-10-2005, 06:48 PM
Bluepen's Avatar
Bluepen Bluepen is offline
Just a firefighter
Last wiki edit: How to title a hot rod
Last journal entry: New rear rollpan installed
Wiki Edits: 2
Like it has been said they are great for waterborne finishes so it will work great if you want to re-finish some furniture. When I was using one in my wood shop I did find that the filter clogged up pretty quick from the poly, what I did to solve the problem because of the short hose, was I found that a 3/4" garden hose would fit with the same threads so I just got a 25' NEW hose and left the turbine outside or in the next room. Worked out great after that.
David
