Anyone use a chemical bond to replace/patch panels?
I have heard some good things about using a chemical adhesive to put on panels, I think it's called Bond? I have a few small holes to fix and do not weld. I have heard some good things about this product, and wondered if anyone had experience with it. Basically a two part epoxy? applied through a gun. You flare and overlap the panels and it joins them as strong as a weld and keeps out the water.
I like to glue what I can. I never overlap, as you need too much filler to level. However, I will glue in an insert then glue to that. Nice and level to start. There are many brands out there and most name brands are very good. Your local jobber will have brand specific documentation and TDS info. If for example, I'm doing a one off rod.... I glue. If I'm putting a new quarter on a show 68 Chevelle....I plug weld with insert the sail panel and resistance weld the rest to resemble factory.... Bryan
I talked to m my brother in law tonight about what he used, something called fuzor. He put quarter panels on his 67 mustang with it. It's a two part agent with glass bead in it. His opinion is quite high of it. Said it took very little fill to level it out, and no risk of warpage. There was some drilling and screwing to keep it in place till dry then you could remove the screws and weld in the few screw holes.
A problem was if you got any outside the seam, on the metal you had to sand it all off or paint would not stick to it. I'm going to look up some info online on it and get back, but I think I may try this route, and learn to weld a little later on my bigger project. |
Since some of the stuff coming from Detroit has glued on panels, I would think it would work fine. I would have some concerns on welding up screw holes around it. I don't know how the stuff reacts to the heat. You may loose the bond from the heat of the welds. I've seen the guys in the shop use heat guns to take the panels off.
I've heard that with welding a body panel, it's prone to rusting and warping......warping is easy enough to work around, by tack welding the whole piece...... but i always worry about rust....
I'm new to body work though.... so not too sure about how big a problem welding is.... But I've heard some good things about this glue stuff as well..... No rust problems.... no warp problems..... Dunno.... I hate rust.... I've got to fix the wheel wells on my car.... and i've been waiting to find out about this glue stuff...... I can weld.... i just would like it to never rust again...
First I'm worse than a crappy welder, I have never welded successfuly. Also the bond's not coming out till you hit 300 degrees either, at which point your doing it on purpose, OR your car is on fire... I have a couple small repairs on my 54, and the choice now is do it myself quicklly, or pay someone to do it for me, or invest $$$ in a welder, and take a long time to learn to weld.
I used panel bond from 3m on my 66 nova quarters.It worked great.A sure fire way to keep the panel tight to the existing metat is to use deodymium magnets .They hold strong.One on the iste and one on the outside.Placed about 3 inches apart.I used the 1/2 inch magnets found on e-bay.When these magnets are stuck together it is close to impossible to pull them apart.You can also use the smaller ones to hole paper in place when paintig.Amillion uses and they can be reused.
How long have you had them on there, any signs to give them away?
sold the car but buyer seems to love the bodywork....2 years later.
I flew a Grumman Tiger for years and it was glued togther, aluminum bonded is what they called it but it was glue. I never had a problem with anything coming off on that so I cannot see you having a problem with using the correct glue on you car. Heck the doors on the chevy's from 88 on have been glued and then the front fender bolted to that.
Like anything else I am sure there is a wrong way to do things so if done wrong I bet you could have problems but what's not like that. |
Re: Anyone use a chemical bond to replace/patch panels?
This has been used is Corvettes since the early 70's (as a greenish adhesive) Enjoy!! |
