Anyone use one of these Mustang power steering kits? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2008, 08:41 AM
Last journal entry: Bringing home the 401 Nailhead
I have a 68 Mustang manual steering box under a 39 Willys w/dropped axle. Been thinking of converting to power steering and keep seeing these kits:
http://cgi.ebay.com/ebaymotors/1964-...Z1218464946841
Has anyone ever used these? Expensive? - yes. Just reading the description on the box makes me very leary (even worse than my communication skills) but seems like a very simple way to put power steering under the Willys and keep the stance.
Old 08-15-2008, 03:49 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Why you do care which components steering-wise command attention of your consciousness specifically? Utilization of installing after the industrial installation this box particularly suits to your intentional work-wise application.
Old 08-15-2008, 06:48 PM
I'm sorry but you lost me or are you being facetious? Maybe you are driving home a point. Stay away from this kit?
Old 08-15-2008, 07:05 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Hey, just think, if they let a MAJOR error like the description go by the inspectors, just think of what great quality control you will find in the box.
Old 08-15-2008, 10:42 PM
Wiki Edits: 21
Just giving the same advice as on the box!
Old 08-16-2008, 07:03 AM
Thanks all. Figured as much but needed confirmation.
Old 08-16-2008, 07:24 AM
1947 Chevy Coupe
Looks like chinese junk to me.
Having a house in the Glendale (Phoenix) area, and having scouted out hot rod shops there, I have never seen that store. Next time I'm in Phoenix, I'l see if I can check it out.
Old 08-16-2008, 07:38 AM
F&J F&J is offline
That would be my concern as well. A friend bought an aftermarket new manual box for an unrelated car (and it was made in South America, I think).
When I put it in, I could not find the normal "high spot" that is supposed to be machined into the gear set. There needs to be that "spot" so you can set the proper freeplay as the wheel is turned slightly off center in either direction. All I could find was a bind about a half turn from full lock to the right
So, wasted money, and a car that still does not feel right. It actually won't return that good as you come out of a turn in one direction.
That's a shame about not being able to trust that setup, as I know people with early Mustangs that want to go to P/S, but don't want the old type slave cylinder.
Old 08-18-2008, 11:22 AM
As far as I know it a steering box from a Toyota. The picture of the kit is taken from this side: www.abspowerbrake.com/newproducts.html
Old 08-18-2008, 03:00 PM
I remember seeing something about this thing on one of the Mustang forums sometime back and they were bad-mouthing it pretty bad. The main thing they were upset about however may not be a problem for you, the angle it was mounted and the pitman arm length was wrong. It is a Toyota box and as such it should be decent quality but if it is the same vendor then look out! I think they were all having trouble getting in touch with him for help with the problems but as I said before it was mostly pitman arm and box mounting angle problems which may not matter much if it is not to be a Mustang installation.
Old 08-19-2008, 06:31 AM
This is encouraging. I really don't want the kit. All I want is a power assist steering box. Since I already have a mustang box I was hoping I could just bolt this box in place and connect to a pump.
Any idea what year Toyota? Guess I better check the Toyota boards as well as the Mustangs.
Old 08-19-2008, 10:44 AM
It don't look like the same box, but there is pics and info about using a Toyota box in a Mustang in this long thread. Pics of the box on this page: http://forums.vintage-mustang.com/sh.../1464767/tp/4/
Mustang II Power Steering Rack Dave42 Suspension - Brakes - Steering 7 02-13-2006 05:26 PM
Power steering conversion 63 econo Suspension - Brakes - Steering 4 05-23-2005 06:32 PM
Replace arm strong steering to power in your 51 to 54 Chevy car Michael Bryan Suspension - Brakes - Steering 3 05-08-2004 09:50 AM
1952 Chevy car power steering box what will work? Michael Bryan Suspension - Brakes - Steering 3 04-17-2004 10:15 AM
68 power steering burner Suspension - Brakes - Steering 5 04-06-2004 08:20 PM
