We're winning the case!
Hotrodders Bulletin Board > Tech Help > Garage - Tools
  #1
Old 08-19-2008, 03:13 PM
FRANKBULLITT's Avatar
FRANKBULLITT FRANKBULLITT is offline
anyone used an astro windshield remover?
Just wondering if its worth getting one. I have real trouble removing them, with the old long utility knife.
Looking for someone who has used it and if it really works thanks.
Old 08-24-2008, 08:14 AM
timothale timothale is offline
windshield tool
I had a tool but the last time i needed to pull one I couldn;t find it, I use a utility knife around th outside and coat it with motor oil, from the inside I use a thin and flexible kitchen knife and also coat it with a lot of oil .. the cable that you thread thru and try to saw thru usually chips the edge of the glass and leaves a potential for later cracks
Old 09-03-2008, 01:41 AM
47dodge's Avatar
47dodge 47dodge is offline
I have one. I like it a lot. Sometimes it is hard to get in tight spots though. It cuts right through windshield seals as long as you keep the blade really sharp. If the blade gets dull it's just about worthless. I just sharpen the blade before I use it every time. I can pull out a windshield in about 5 minutes and I haven't broken a windshield while removing it since I got it.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "anyone used an astro windshield remover?"
Flush fitting a windshield. Stovebolter Body - Exterior 4 05-19-2009 04:58 PM
Which Butyl tape to use for 67 Impala windshield impalaalex Body - Exterior 3 08-10-2007 07:24 AM
Windshield Wiper on '31 Roadster Irelands child Body - Exterior 2 03-24-2006 06:21 AM
Cutting curved windshield swoodard23 Body - Exterior 16 08-05-2005 10:27 AM
Spot weld driller Shoot out! MARTINSR Body - Exterior 5 05-30-2005 05:46 PM
