anyone used Lizard Skin? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2006, 12:14 PM
Hello
I was curious if anyone has used Lizard Skin.?(noise/heat reduction) I would like to know how well it works and if anyone has had problems with it?
If something else out there is better, or if people have better results with another product, please let me know
thanks
Tom
Old 01-03-2006, 03:50 PM
73oldsman's Avatar
I thought you were talking about lizardskin for upholstery work. Never heard of it as a sound deadener but did a search and found out it was previously discussed in this thread...Using aeresol spray expandable foam in body ? Maybe this will help you some!
Old 01-05-2006, 07:34 AM
Lizard Skin
Hi, I have just sprayed my car with Lizard Skin. I removed the entire interior and all the trunk carpeting. I am in the process of reinstalling the upholstry and carpet now. Can't say how well this stuff will work but am encouraged by the performance so-far. My car ( 1948 Buick 2 door sedanette) was noisy and hard to cool. I bought this car and most of the work was already done. The builder did not think insulation was important and the nice interior was installed over bare and painted metal, even the firewall was just painted metal. I sprayed two coats of Lizard Skin on the entire inside of the car and the trunk. The stuff seems to adhere well and I have not seen any signs of peeling even after crawling all over everything to reinstall the interior. I used almost two buckets of material and did purchase the special spray gun sold by the Lizard Skin dealer. Not cheap, if it works like they say it will, it sure will be worth it!
Good luck!! Buford.
th
Name:	'050507 LFront.JPG
Old 01-05-2006, 08:17 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
you will be pleased. it really works as advertised. beats coolmatt hands down.
Old 01-05-2006, 11:47 AM
73oldsman's Avatar
Sweet '48 buick.
Old 01-05-2006, 12:04 PM
Lizard Skin
Hello
Thanks very much for the info. I have an old Corvette, and it is being built as a street/strip car. I have not bought anything yet for heat/noise retention, but was told of this product.
Thanks for the info
Tom
Old 01-05-2006, 12:21 PM
shine's Avatar
SPI Thug
i'm doing a restoration on a 57 vette that will get it and a 56 big window chevy .the 56 is like airconditioning a green house. it's just cleaner than cut and glued.
Old 01-05-2006, 01:49 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
thanks for the info I thought this was going to the truck stop & lot lizards
SR66
"SlowRide66"
"Illegitimis non carborundum"
Old 01-24-2006, 10:45 AM
Lizard Skin
Well I got the interior back into my '48 Buick Roadmaster and felt I should report my impressions of Lizard Skin insulation. WOW!! my car is totally different now, it is very quiet and I can hear the stereo at 70 MPH. The weather here is quite cool so I can't report on how the A/C works but I can tell how much tighter the car feels and I almost have to leave a window open a small amount to get the doors to close. I am very happy with the results and would recommend this product to any one considering insulating your ride.
Name:	'050507 RRear HoodUp.JPG
Old 01-24-2006, 05:17 PM
Lizard Skin
Hello Dingman
Thanks very much on your post. I have not been able to find anyone who has used the product yet, so I am glad to hear from someone who has
Have you used Dyna-mat, or can you compare Lizard Skin to something else you may of used before??
Did you spray it on?? Did it cover exactly as they say, or was it more?
I have to do my vette this spring and I will need something good. I have no experience in any sound/ heat deadening products, so I would like to hear any other info you may have on it( it's effectiveness)
I am going to some big noise and heat issues, and I do plan on some longer cruises with it
thanks
Tom
Old 01-24-2006, 06:43 PM
Lizard Skin
My car was noisy and hard to cool, I live on the desert where it is really hot for several months of the year. I have not used Dyna-Mat, I have used other similar foil faced products. None of the others can compare, I think the Lizard Skin people are very realistic and the product covers as they estimate. It is not cheap but after using it I can see that it amounts to close to the same expense as cut and fit products but is much faster and more importantly it really is better! I did my Roadmaster Buick with two buckets of material, that includes the entire trunk area and all the cabin of this large car in two coats. It is not too thick, they recommend about .060 final thickness but it is a terrific thermal barrier as well as a sound deadner. My car is dramaticly different with this stuff. I also bought the special spray-gun that Lizard Skin sells, I will probably use this product again and since it is water based it doesn't have terrible fumes and the gun is easy to clean. Good luck with your project, it would be nice to hear what you decide to do with your car.
Old 12-01-2006, 08:23 PM
solidaxel's Avatar
Last journal entry: Project garage complete!
Lizzard skin
OK Dingman, summer has come and gone how did the lizzard skin work with the A/C??
Old 12-01-2006, 08:56 PM
302 Z28's Avatar
Take a look in the General Rodding Tech forum, I found a much cheaper alternative to the over priced Lizard Skin.
Vince
Old 12-02-2006, 06:35 AM
Lizard Skin
I have to say the Lizard Skin is impressive, my car is really easy to cool and is much quieter than before I sprayed it with this stuff. I agree with some of the other guys in that it is rather expensive but in my case it is worth it for the comfort it provides.
Old 12-02-2006, 06:46 AM
shine's Avatar
SPI Thug
i learned many years ago to not shop for price when it comes to quality. on a 40k car a few hundred for lizardskin is chump change. there s always some market hype about cheaper products. you only get one chance to do this and it's better to use quality. same with cheap paint or cheap parts.
Lizard Skin Cole Interior 1 01-05-2006 07:37 AM
59 Chevy Pickup Door Skin KennyB Body - Exterior 5 09-12-2005 11:10 PM
Door Re-Skinning Taco Body - Exterior 6 05-04-2005 10:44 PM
Door Skin Replacement bmech211 Body - Exterior 5 11-25-2003 06:25 PM
"55' chevy door skin? Dave Y. Body - Exterior 3 09-16-2002 12:20 AM
