anyone useing afr eliminater heads? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2008, 05:30 PM
406 ss monte's Avatar
eat a beaver, save a tree
i have a set of dart pro-1 215cc heads & are not the platinum heads. i'm wondering if a set of Afr 195cc or 210cc eliminator heads would be a better head for my 406. would the Afr heads make enough power to justify the switch? i would sell the darts to help pay for the Afr heads. i'm guessing i would have about $600 out of pocket cost. would it be worth it?
my cam is a Lunati solid lift 249-259 @.050" .543"-.561" lift on a 106 l/s. 1 3/4 headers, 10.5 compression, 750 dp Holley. i have a victor jr, team g, & rpm air gap intakes. all three would be good to use. 3500 pound car with 3.42 gears, & a 3,500 edge racing converter.
i'm also thinking of going to a smaller cam if i do the swap.
Why spend money on heads? F-1Rodder Engine 8 03-07-2008 12:09 AM
Afr Heads ???? 66sedanman Engine 1 11-07-2007 10:14 PM
AFR heads BigTex88 Engine 2 02-07-2006 06:29 AM
New heads is this a problem? strikingthematch Engine 5 10-27-2004 04:15 AM
Help! I need to find out where a set of heads i have came from by useing the casting# lt13501 Engine 3 07-22-2003 10:39 AM
