Anyone using a MSD E-Curve distributor? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2007, 03:29 PM
frankenvette's Avatar
Go ahead kid squeeze the wheez
http://www.msdignition.com/dist_83_8394.htm
My Bad! I did a search and found a couple here and a couple on other forums.
However, if anyone has been using one for any length of time and has some suggestions or feedback on how it's working out, I would appreciate a response.
Old 07-03-2010, 02:32 PM
E-Curve
I am using one and it's very cool. As everyone probably knows by now the instructions are terrible and make it difficult to understand, otherwise no problems from mine. Easy to change curve, put a MSD box on it, super conductor wires and it run's awesome. Set curve at 36 full advance x 20 degrees x 2,000 rpm.
Camminc
http://www.cammhsm.com
Old 08-02-2010, 11:46 AM
Proud LOSER
Camminc
Yup, start retard is cool....changes are a breeze, ins suck bad....called msd, teh tech dude said he was sorry they sucked so much and walked me through the right way to set it up....6a box, street fire wires, runs great...
Old 08-02-2010, 01:36 PM
NOlowrider's Avatar
US Navy-Retired
I have one and I really like it. I have it for about 2 years with no problems. The insturctions do suck, but once it was explained to me by MSD it is not too bad. I needed total 36*, tech told me to set both switches to "0", set the total, then set it for the curve once the total has been set. Take the total, substract the initial you want and the remainer will the % curve that you need.
However, take a look at the Crane unit. The switches are on the outside (not under the cap). Seems easier if you want to switch curves. Don't have to remove the cap. IMO
But I do love my e-curve.
New MSD Distributor dpjmw Engine 1 09-22-2006 06:52 PM
Oil leak at MSD distributor base? TVR383 Engine 2 10-28-2005 03:37 PM
MSD Pro-Billet Ford FE Distributor tomcasino Engine 4 09-22-2005 05:03 PM
msd distributor question...specifically about vac adv canister 357ford Electrical 0 09-12-2004 04:17 PM
MSD offroad-6, MSD 8366 Distributor, Holley 950 ECU izord Electrical 0 09-06-2004 02:16 PM
