-   -   Anyone using a parallel spring solid axle? (http://www.hotrodders.com/forum/anyone-using-parallel-spring-solid-axle-133955.html)
Chevrolet4x4s 02-23-2008 08:02 PM
Anyone using a parallel spring solid axle on their fenderless hotrod? Should be fine for a truck right?
Shane
powerrodsmike 02-23-2008 11:35 PM
Makes the front frame rails stick out all big like buck toothed fangs....Leave the fenders on.. :D
JMO, mikey
1930u 02-24-2008 07:10 AM
Shane
I'm building an old 30 Plymouth Coupe. The chassis is an original with parallel springs. Here's a picture from back in the summer. I'm trying for a late sixties drag profile and I will be using motorcycle fenders.
For more pics see the 1930u journal.
1930u 02-24-2008 07:12 AM
1 Attachment(s)
sorry forgot picture
Chevrolet4x4s 02-24-2008 08:10 PM
Looks Great. Is 0.1196" thick enough for a 2x3 boxed chassis? About what does 2x3 tubing go for?
Shane
1930u 02-24-2008 08:26 PM
Shane
Thanks, I've been busting my hump on this thing all winter. I'm probably not the guy to advise you on the tube specs. My chassis was actually built by a professional IHRA racer back in the late 60's, But I'm sure someone here will be able to help you. Otherwise you could check the NHRA spec. book or check with a fabricator or race shop.
I also saw a straight axle kit on eBay the other day. It was suppose to be an engineered system..it was really cool.
Chevrolet4x4s 02-25-2008 05:13 PM
Your welcome, Its going to be amazing when you get it finished, Have you decided what color your going to paint it?
Shane
1930u 02-25-2008 08:39 PM
I love black but this one can only be candy apple red. I'm not going to use real candy because I plan to drive this car often...so I want something I can spot repair. Right now I'm investigating some new motorcycle paint jobs. Many look like true candy but their just a conventional 2 stage paint process.
Actually, there's a candy red washer and dryer at Sears thats a dead on what I'm looking for too. So I'm trying to invetsgate that paint too. I'm a ways off but I continue to work on this junker every spare minute I get.
