Anyone using a parallel spring solid axle? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2008, 08:02 PM
Anyone using a parallel spring solid axle on their fenderless hotrod? Should be fine for a truck right?
Shane
Old 02-23-2008, 11:35 PM
powerrodsmike's Avatar
Wiki Edits: 161
Makes the front frame rails stick out all big like buck toothed fangs....Leave the fenders on..
JMO, mikey
BE different....ACT normal.
Old 02-24-2008, 07:10 AM
1930u's Avatar
Last journal entry: 1930u Its just been sitting
Shane
I'm building an old 30 Plymouth Coupe. The chassis is an original with parallel springs. Here's a picture from back in the summer. I'm trying for a late sixties drag profile and I will be using motorcycle fenders.
For more pics see the 1930u journal.
Old 02-24-2008, 07:12 AM
1930u's Avatar
sorry forgot picture
Name:	Current weight 1975 lbs.jpg
Old 02-24-2008, 08:10 PM
Looks Great. Is 0.1196" thick enough for a 2x3 boxed chassis? About what does 2x3 tubing go for?
Shane
Old 02-24-2008, 08:26 PM
1930u's Avatar
Shane
Thanks, I've been busting my hump on this thing all winter. I'm probably not the guy to advise you on the tube specs. My chassis was actually built by a professional IHRA racer back in the late 60's, But I'm sure someone here will be able to help you. Otherwise you could check the NHRA spec. book or check with a fabricator or race shop.
I also saw a straight axle kit on eBay the other day. It was suppose to be an engineered system..it was really cool.
Old 02-25-2008, 05:13 PM
Your welcome, Its going to be amazing when you get it finished, Have you decided what color your going to paint it?
Shane
Old 02-25-2008, 08:39 PM
1930u's Avatar
I love black but this one can only be candy apple red. I'm not going to use real candy because I plan to drive this car often...so I want something I can spot repair. Right now I'm investigating some new motorcycle paint jobs. Many look like true candy but their just a conventional 2 stage paint process.
Actually, there's a candy red washer and dryer at Sears thats a dead on what I'm looking for too. So I'm trying to invetsgate that paint too. I'm a ways off but I continue to work on this junker every spare minute I get.
Tip of the day #28 Hood spring installation. MARTINSR Body - Exterior 23 11-16-2012 10:16 AM
1999 Jeep Cherokee Rear Axle Seals - Help leejoy Transmission - Rearend 2 05-15-2007 07:50 PM
moving rear coil spring location to change rate cboy Suspension - Brakes - Steering 32 03-01-2007 11:31 AM
7 and 5/8 rear end drivers side axle leaks fumplet Transmission - Rearend 7 03-02-2006 01:39 AM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
