Anyone using these valve cover hold downs from Spectre? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2010, 06:53 PM
http://www.spectreperformance.com/#CATALOG.52985
OK, here's the dealio.....
One of my passenger side valve cover bolt holes is stripped
I plan on installing a heli-coil, but also want to add studs to all of the holes so I can pull the covers for valve adjustments without ruining anymore threads
Now, the usual T-Bolts/Wing-Bolts won't fit because my motor is recessed into the firewall and has minimal clearance for the rear bolts
So I'm looking into skinny hold downs that have separate studs like the Spectre ones above
Anyone use these?
Are the caps steel or plastic?
The local speed shops don't carry them on the shelves, so I can't see for myself until I place an order
Old 09-19-2010, 07:05 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
They look pretty good i have never used them, But the stem itself being billit steel you would think the cap would be also. I wonder if the cap screws down or is a press on cap to acess the allen head for tightening.
Cole
Old 09-22-2010, 10:29 AM
OK, I ordered 4 sets from Amazon and they just came in...
The caps are steel and they screw onto the threaded top
Very solid
Old 09-22-2010, 02:27 PM
Some pix
Old 09-26-2010, 09:41 PM
Installed
Old 09-26-2010, 09:47 PM
Landshark928's Avatar
FrankenPorsche
Might have to get some. I need studs. It's such a pain to keep the gasket inline when putting on the covers. Look nice.
Sick ride BTW!
Old 09-26-2010, 10:08 PM
Yeah, they drop in nicely with the studs in place, but my main reason for going with the studs is because one of the holes got stripped
Had to install a hei-coil, but it wasn't easy
My dad took my angle drill to do a camera install at Disney, so I had to make due with a piece of $h!t HF 90* adaptor :o
The drill bit was too long, so I had to hack it with a cut-off wheel, but then it wouldn't center on the drill chuck because of the grooves, so I had to weld the grooves and grind it round just to get it centered
The whole setup just barely fit, but it worked
Old 09-27-2010, 12:33 PM
ericnova72's Avatar
More for Less Racer
Looks sharp
Always has to be the worst one to get to that strips, doesn't it?? Couldn't be one right out in the open.
Do you know if they make them in different lengths??
Old 09-27-2010, 05:18 PM
I don't think Spectre does, but I've seen other similar styled ones that are slightly shorter, like these Billet ones....
Not sure if the studs are removable though
Old 09-27-2010, 05:30 PM
eloc431962's Avatar
Wiki Edits: 37
Looking good. I really like the way they look, i will check into the shorter ones.
Cole
Old 10-06-2010, 05:33 PM
Picked up a matching dipstick
Old 10-08-2010, 03:30 AM
jon72vega's Avatar
WOW, I could have had a V8!
Looks good!
Jon
http://1972vega.wordpress.com/
Old 10-08-2010, 10:22 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
Just another approach, for me I installed studs and used washers and nuts to fasten the valve covers. That will work in crowded areas, clean appearance, and they stay tight. Not knocking the specter stuff but those T handle and extended valve cover fasteners have a tendency to loose up, keep an eye on them is all I am saying.
Breather/PVC valve in valve cover juiced66malibu Engine 3 08-02-2010 07:28 AM
disk convertion question, hold off valve 65bluess Suspension - Brakes - Steering 5 02-25-2010 06:38 PM
Gray stuff in the valve cover? rthjimmy Engine 3 02-13-2010 04:39 PM
billet rocker hold downs clearances tight help??? charger528 Engine 2 09-25-2007 05:51 PM
Valce cover Oil leak problem / PCV system question hotrodf1 Engine 7 05-01-2007 02:44 PM
